16641 Discussions
Quartus 12. --Analysis and Synthesis Failed- Help Needed
Hello here is a small program that I wrote in VHDL(please see attachment). Synthesis fails in Quartus with the following error.
Error[10028]: can't resolve multiple constant drivers for net wr_data[]...
Can someone help me with solve it?
Manoj
--- Quote Start ---
Manoj
--- Quote End ---
It is telling you you have assigned to write_data in two assignments (the combinatorial logic before stste machine then inside state machine).
Which one you want?
Thanks Kaz, for your reply. I would like to assign both the assignments, as I need it for my logic.
Any idea how to implement it?
Manoj
you should assign to wr_data in one construct but check priority.
wr_data <= x"00" when state = s1 else x"00" when count_reg = x"00" else x"01" when count_reg = x"01" else x"02" when count_reg = x"02" else x"03" when count_reg = x"03" else x"04" when count_reg = x"04" else x"05" when count_reg = x"05" else x"06" when count_reg = x"06" else x"07" when count_reg = x"07" else x"08" when count_reg = x"08" else x"09" when count_reg = x"09" else x"0A" when count_reg = x"0A" else x"FF";
Thanks so much Kaz. It works now!.
Manoj
