Dear all,
I am running Quartus 13.0sp1 because the project uses a Stratix II FPGA. When the fitter starts running it stops with an internal error as follows at the end of the email. The license is in order.
Any help to resolve the issue would be appreciated as I can only this version or an earlier version of Quartus.
Joseph
Internal Error: Sub-system: HDB, File: /quartus/h/qtl_object_cache_sys.h, Line: 1010
m_archive == NULL
Stack Trace:
0x859d0: HDB_ENUM_OPTION::get_value + 0x1aa20
0x4cad7: HDB_CMP_ACTION_PT_INSTANCE::write_pdb + 0x3c7
0x47e49: HDB_FILE_DEPENDENCIES::operator<< + 0x2d9
0x719a: PDB_SEGMENT_WRITER::xfr_new + 0x7a
0x52319: HDB_CHIP::serialize + 0x49
0x46ed3: HDB_ACTION_PT_INSTANCE::operator<< + 0x333
0x50a06: HDB_CMP_ACTION_PT_INSTANCE::operator<< + 0x66
0x7e35: PDB_VIRTUAL_OBJECT_INFO::finish_writing + 0x45
0x7dce: PDB_SEGMENT_WRITER::finish_writing_all + 0x3e
0x7ebc: pdb_write_ptr + 0x4c
0xa8291: HDB_ACF_SEARCH_KEY::set_hdb_assignment + 0x101
0xb31a2: HDB_ASSIGNMENT::begin_generated_option + 0x362
0x8cb36: HDB_ENUM_OPTION::get_value + 0x21b86
0xf9899: HDB_NAME_SERVICE::get_tree + 0x49
0x9fcad: HDB_ENUM_OPTION::get_value + 0x34cfd
0x1b8b9e: VPR_QI_FACADE::vpr_qi_get_start_and_end_progress_bar_perc_for_fsyn + 0x195c9e
0x194cca: VPR_QI_FACADE::vpr_qi_get_start_and_end_progress_bar_perc_for_fsyn + 0x171dca
0x19ad61: VPR_QI_FACADE::vpr_qi_get_start_and_end_progress_bar_perc_for_fsyn + 0x177e61
0x189528: VPR_QI_FACADE::vpr_qi_get_start_and_end_progress_bar_perc_for_fsyn + 0x166628
0x1c0ab8: VPR_QI_FACADE::vpr_qi_main + 0x148
0x2df11: fitapi_run_vpr + 0x71
0x428c8: FITCC_EXPERT::run_vpr + 0x138
0x44760: FITCC_EXPERT::place_and_route + 0x150
0x46df1: FITCC_EXPERT::invoke_fitter + 0x711
0x1474: farm_execute + 0x244
0xb959: fmain_start + 0x7e9
0x2225: Legacy_fitter_Init + 0x11b5
0x1ea8: Legacy_fitter_Init + 0xe38
0x2e68: Legacy_fitter_Init + 0x1df8
0xf8a6: TclInvokeStringCommand + 0xc6
0x112a8: TclEvalObjvInternal + 0x328
0x121b5: TclEvalEx + 0x8d5
0x12d48: TclEvalObjEx + 0x2d8
0x1abbd: Tcl_EvalObjCmd + 0xfd
0x56917: TclExecuteByteCode + 0xe47
0xa2376: TclObjInterpProcCore + 0x76
0x7c117: Tcl_FSEvalFileEx + 0x1d7
0x7a626: Tcl_EvalFile + 0x36
0xbd5f: qexe_ipc_progress_bar_name + 0xf3f
0x11498: qexe_get_command_line + 0x1068
0x147a5: qexe_run_tcl_option + 0x585
0x1dacd: qcu_run_tcl_option + 0xb8d
0x14dbd: qexe_process_cmdline_arguments + 0x54d
0x14f21: qexe_standard_main + 0xa1
0x4c78: msg_exe_fini + 0x58
0x53bc: msg_exe_fini + 0x79c
0x1584: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194
0x5f9f: msg_exe_main + 0x8f
0x17343: BaseThreadInitThunk + 0x13
0x526b0: RtlUserThreadStart + 0x20
End-trace
Quartus II 64-Bit Version 13.0.1 Build 232 06/12/2013 SJ Full Version
Service Pack Installed: 1
Check this old KDB link https://www.intel.com/content/www/us/en/support/programmable/articles/000079701.html probably can resolve your problem.
Sheng
May I know does your problem being resolved?
Sheng
