16642 Discussions
Quartus II synthesis error
I am new to quartus design flow. i invoked .qpf file using quartus II(v9.1). it is giving the following error when i try to synthesis. the design is having nios II system also.
Error: Can't find Memory Initialization File or Hexadecimal (Intel-Format) File /u2/design/Quartus_4_port_ethernet/epcs_controller_boot_rom.hex for ROM instance
Error: Can't elaborate user hierarchy "nios_1:\nios_gen:cpu|epcs_controller:the_epcs_controller|altsyncram:the_boot_copier_rom|altsyncram_1s31:auto_generated"
Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 145 warnings
Error: Peak virtual memory: 324 megabytes
Error: Processing ended: Fri Jun 17 10:37:45 2011
Error: Elapsed time: 00:00:19
Error: Total CPU time (on all processors): 00:00:17
It is giving some error in SOPC builder also.
The following is the error message from SOPC builder.
"can't find the modules ISP1362 and bus_interface_0". But it is available in the project folder.Please note am not created new project. I invoked the old one.
can you please help on this. thanks in advance.
Do you have a /u2/design/Quartus_4_port_ethernet/epcs_controller_boot_rom.hex file?
Are your modules in the project's ip folder? If not I think they need to be added to the SOPC search paths.
It could be because some static paths have been used and your project is now in a different path.
