17093 Discussions
Quartus v18.1 Failed to launch MegaWizard Plug-In Manager: ROM: 2-PORT
JC_FPGA
I cannot update an existing 2-Port ROM nor can I create a new one. This issue sounds like it could be related to the .lst (list) problem where some names are "Altera" instead of "Intel FPGA."
Similar to this thread: https://forums.intel.com/s/question/0D50P00003yyTl2SAE/quartus-18-megawizard-issue?language=en_US
However, I haven't been able to find a .lst file that references the ROM IP. Strangely, I am able to create a 1-Port ROM. It's just the 2-Port ROM that does not work.
I'm using Quartus v18.1.0 on 64-bit Windows.
KhaiChein_Y_Intel
Hi JCox,
Can you use HDL to instantiate the ROM as a workaround at the moment?
To insert the template, right click > Insert Template > Choose the HDL language > Full Designs > RAMs and ROMs
