16680 Discussions
Quartus web edition installation problem on WinXP
trying to install the 10.0sp1 version just downloaded. Extracted the download to C:\quartus_free
from command line tried running
altera_installer_cmd -t=C:\Quartus --temp=C:\QuartusT --source=C:\quartus_free\altera_installer\bin\ -i quartus_free -w
I get the following error
Traceback (most recent call last):
File "<string>", line 1444, in <module>
File "<string>", line 1438, in main
File "<string>", line 1198, in dispatch_command
File "<string>", line 440, in run_install
File "<string>", line 1073, in create_dir
File "windows32\build\pyi.win32\altera_installer_cmd\outPYZ1.pyz/os", line 150
, in makedirs
File "windows32\build\pyi.win32\altera_installer_cmd\outPYZ1.pyz/os", line 157
, in makedirs
WindowsError: [Error 123] The filename, directory name, or volume label syntax i
s incorrect: 'C:\\quartus_free\\altera_installer\\bin\\=C:'
can someone help me out if I'm doing something wrong please?
Hi
you should use " on your paths if you wrote exactly the lines you printed here. "C:\Program Files (x86)\Quartus and so on"
Using quotes gives exactly the same error
here's the command
altera_installer_cmd -t="C:\Quartus" --temp="C:\QuartusT" --source="C:\quartus_free\altera_installer\bin" -i quartus_free -w
Maybe the command is jumbled: on http://www.altera.com/support/kdb/solutions/rd07212010_875.html (http://www.altera.com/support/kdb/solutions/rd07212010_875.html) we find the syntax:
-t TARGET_DIR
or
--target=TARGET_DIR
I would try:
altera_installer_cmd.exe --target="C:\Quartus" --temp="C:\QuartusT" --source="C:\...\Temp\10.0_quartus_free_windows" --install=quartus_free -w
Thanks it's worked now. Indeed it seems that it didn't like mixing the long and short option syntaxes.
