SR latch test bench help
Hey im not sure how to make a testbench for an sr latch, the code ive made is shown below for the latch and the testbench.
for the latch
library ieee;
use ieee.std_logic_1164.all;
entity tut6a is
port (
end tut6a;
architecture struct of tut6a is
signal r1 , s1, qa , qb : std_logic;
attribute keep : boolean;
attribute keep of r1 , s1 , qa , qb : signal is true;
begin
r1 <= r and clk;
s1 <= s and clk;
qb <= not (r1 and qa);
qa <= (s1 and qb);
q <= qa;
end struct;
for the testbench
library ieee;
entity Testbench6a is
end Testbench6a;
architecture struct of Testbench6a is
component tut6a
port ( clk , r , s : in std_logic;
qa , qb , rl , sl : out std_logic);
end component;
signal s , r , q : std_logic := '0';
signal rl , sl , qa , qb : std_logic := '0';
signal clk : std_logic := '1';
begin
inst1 : tut6a port map( clk ,
r ,
s ,
qa,
qb,
rl,
sl );
process
begin
s <= '1';
r <= '0';
wait for 10 ns;
s <= '0';
r <= '1';
wait for 10 ns;
s <= '1';
r <= '1';
wait for 10 ns;
end process;
end architecture;
What exactly do you need help with? It looks like you are following a tutorial (given an entity name name tut6a). If so, did you read something in this tutorial, or the ones before, regarding port mapping and such things?
Im having problems getting an output in the simulator in modelsim for rl sl qa and qb, i changed the code a bit so it shows r s and q on the simulator.
library ieee;
end Testbench6a;
component tut6a
q : out std_logic);
end component;
begin
r ,
s ,
q );
process
begin
s <= '0';
r <= '0';
wait for 10 ns;
s <= '1';
r <= '0';
wait for 10 ns;
s <= '0';
r <= '1';
wait for 10 ns;
s <= '1';
r <= '1';
wait;
end process;
end architecture;
--- Quote Start ---
--- Quote End ---
Do you see rl sl and both q's in the simulator but do they have the value 'U' or do you not see them at all?
