16672 Discussions
Simulation Visualiation on Linux
I am using Ubuntu, when I try to use ModelSim-Altera tu run a RTL simulation, I get the messages:
Info (22036): Successfully launched NativeLink simulation (quartus_sh -t "/home/eduardp/altera/13.0sp1/quartus/common/tcl/internal/nativelink/qnativesim.tcl" --rtl_sim "register" "register")
Info (22036): For messages from NativeLink execution see the NativeLink log file /home/eduardp/ProjetosAltera/TutorialVHDL/register1bit/register_nativelink_simulation.rpt
But nothing shows up. ModelSim seems to work fine when I open it using ./vsim.
Someone else asked this at http://www.alteraforum.com/forum/archive/index.php/t-48630.html , but it's not solved and my problem seems not to be ModelSim installation nor my OS.
This is the file register_nativelink_simulation.rpt :
Info: Start Nativelink Simulation process
Info: NativeLink has detected VHDL design -- VHDL simulation models will be used
========= EDA Simulation Settings =====================
Sim Mode : RTL
Family : cycloneii
Quartus root : /home/eduardp/altera/13.0sp1/quartus/linux/
Quartus sim root : /home/eduardp/altera/13.0sp1/quartus/eda/sim_lib
Simulation Tool : modelsim-altera
Simulation Language : vhdl
Version : 93
Simulation Mode : GUI
Sim Output File :
Sim SDF file :
Sim dir : simulation/modelsim
Info: Starting NativeLink simulation with ModelSim-Altera software
Sourced NativeLink script /home/eduardp/altera/13.0sp1/quartus/common/tcl/internal/nativelink/modelsim.tcl
Warning: File register_run_msim_rtl_vhdl.do already exists - backing up current file as register_run_msim_rtl_vhdl.do.bak8
Info: Spawning ModelSim-Altera Simulation software
thanks in advance
I'm using Fedora and had the same problem. As it turned out, Quartus starts ModelSim, but ModelSim itself cannot run due to some problems; however, Quartus only saw that the ModelSim process started, and reported that everything was successful.
What helped me are these two articles: https://wiki.archlinux.org/index.php/altera_design_software#modelsim-altera_edition (https://wiki.archlinux.org/index.php/altera_design_software#modelsim-altera_edition) and http://mattaw.blogspot.de/2014/05/making-modelsim-altera-starter-edition.html (http://mattaw.blogspot.de/2014/05/making-modelsim-altera-starter-edition.html).
In a nutshell:
  • manually execute ModelSim from the shell to see what it tells you; the executable is /installation_path/modelsim_a
  • you probably need all sorts of packets to be installed manually
  • you probably have to modify the ModelSim startup script (the same file as in my last bullet point), to be compatible with your Linux version
  • you probably have to install an old version of the freetype library, because the latest and greatest that is installed with modern Linux distros is incompatible with ModelSim
I have to admit that I never use NativeLink, as manually writing scripts for ModelSim is way more conventient, but I double-checked that on my system invoking ModelSim through NativeLink from Quartus works.
GooGooCluster
Thanks for your answer!!
I followed the steps in both links, I had mad the freetype thing before, I think what really made it work was setting modelsim_ase/bin instead of modelsim_ase/linuxaloem as the path to modelsim-altera
