17255 Discussions
Strange problem in synthesis of counter
I am currently writing a learning module on creating a mod-counter. When I attempt to demonstrate the concept of a mod-6 counter using the 4count symbol and a NAND2 as feedback to the CLRN port, I can not count beyond binary 3. The configuration is as follows: QB and QC output of 4count connected to inputes of NAND 2. Output of NAND2 tied to CLRN of 4count.
Both vector waveform and programming DE1 has the error. Any ideas?
The problem is caused the asynchronous character of the 4count clrn input. You can't build a reliable counter this way. Use a synchronous reset from 5 to 0 instead.
Thank you! It is funny that I have five books that say otherwise so it was quite frustrating trying to demonstrate a mod counter. The solution you provided works great.
The asynchronous feedback modulo logic only works with an asynchronous ripple carry counter. Here the stages are toggling one after the other. I have build many similar counters with discrete TTL and CMOS logic in the past.
4count is a synchronous counter, so all outputs are toggling at the same time. Depending on accidental delays, you can get a reset glitch during the transition 3->4.
