I've been playing around with my models behavior to try and combine it into one process. However when I simulate it I am getting some odd results. Iv'e attached a jpeg of the testbench results. 1. The simulation does not work for the 1st clock cycle. 2. At time 24 ns, outputs a and f show '1'. This is during count 5, where the code states they should be at '0'. 3. At time 50 ns, reset is '1' - this should hold the process at count 0 (only c and d are '1'). However it does not happen. Could anyone shed some light onto this for me? Code is: entity seq2 is port (clk : in std_logic; enable : in std_logic; reset : in std_logic; a,b,c,d,e,f : out std_logic); end seq2; architecture behaviour of seq2 is signal count : integer range 0 to 5; signal vector : std_logic_vector (5 downto 0); begin process(clk, enable, reset) begin if reset = '1' then count <= 0; elsif falling_edge (clk) then if enable = '1' then if count < 5 then count <= count + 1; case count is when 0 => vector <= "001100"; when 1 | 5 => vector <= "011110"; when 2 | 4 => vector <= "110011"; when 3 => vector <= "100001"; end case; else count <= 0; end if; end if; end if; end process; a <= vector(5); b <= vector(4); c <= vector(3); d <= vector(2); e <= vector(1); f <= vector(0); end behaviour;Link Copied
I think waveform is correct. You can observe that once reset is applied to the design,you will get the expected data. As you are not applying reset at start up,count value will be undefined. You should reset the sequential logic first. You haven't added count signal.Observe the count signal.
This simulation is working exactly as you coded it. I think you're forgetting that a-f are syncrhonous to the clock. And you have also not reset the vector signal, therefore the reset works like a synchrous enable for the vector signal (ie. reset = '1' means do not update vector) therefore a-f will not change.
Thanks for the explainations, I understand what went wrong with the reset now. Thank you for explaining it to me guys!
