Hi Everyone,
I'm new to OpenCL and trying to learn from the official Altera OpenCL design examples. Here is one question that might be naive, but I just could not find an answer (tried to search for a similar thread too): In the FFT(1D) design example (https://www.altera.com/support/support-resources/design-examples/design-software/opencl/fft-1d.html), a struct of 8 float2 members is defined in fft_8.cl: typedef struct { float2 i0; float2 i1; float2 i2; float2 i3; float2 i4; float2 i5; float2 i6; float2 i7; } float2x8; So what is the point of using the struct (which forces related code to be "hardcoded"), instead of using an array float2[8] here? Does it increase the efficiency of compilation / execution? It would be great if the source of that info could be provided as well. Thanks a lot in advance, and have a great weekend! -TianLink Copied
