I everything inside the always @ totally different and it compiled without errors but it definitely didn't do what I wanted it to. It counted the seconds fine but everything else was whacky so I started over. Any tips or suggestions on how I can make the errors go away and I can compile this?
module clock(set,onehertz,hour,minute,ampmset,hr_ten,hr_one,min_ten,min_one,sec_ten,sec_one,am_pm);
input onehertz,hour,minute,ampmset,set; //SW0 to set, KEY3 for hours, KEY2 for Minutes, KEY1 for AM or PM
output hr_ten,hr_one,min_ten,min_one,sec_ten,sec_one;
output am_pm;
reg hourtens,hourones,mintens,minones,sectens,secones;
reg ampm;
always @ (posedge onehertz) begin
if (set == 0) begin
secones <= secones+4'H1;
if ( secones > 4'H9 && sectens < 4'H6 ) begin
secones <= 4'H0;
sectens <= sectens+4'H1;
end else begin
sectens <= 4'H0;
minones <= minones+4'H1;
end else if ( minones > 4'H9 && mintens < 4'H6 ) begin //Line 18, first error
minones <= 4'H0;
mintens <= mintens+4'H1;
end else begin
mintens <= 4'H0;
hourones <= hourones+4'H1;
end else if ( hourones > 4'H9 && hourtens == 4'H0 ) begin //Line 24, second error
hourones <= 4'H0;
hourtens <= hourtens+4'H1;
end else if ( hourtens > 4'H1 && hourtens == 4'H2) begin
hourtens <= 4'H0;
if (ampm == 7'B0001100) begin
ampm <= 7'B0001000;
end else begin
ampm <= 7'B0001100;
end
end
end
if (set == 1) begin
if (hour == 1) begin
if ( hourones > 4'H9 && hourtens == 4'H0) begin
hourones <= 4'H0;
end else if ( hourtens == 4'H1 ) begin
hourtens <= 4'H0;
end
end
if (minute == 1) begin
if ( minones > 4'H9 && mintens > 4'H5) begin
minones <= 4'H0;
mintens <= mintens+1;
end else if ( mintens > 4'H5 ) begin
mintens <= 4'H0;
end
end
if (ampmset == 1) begin
ampm <= 7'B0001000;
end else begin
ampm <= 7'B0001100;
end
end
end
end
assign hr_ten = {hourtens};
assign hr_one = {hourones};
assign min_ten = {mintens};
assign min_one = {minones};
assign sec_ten = {sectens};
assign sec_one = {secones};
assign am_pm = {ampm};
endmodule
Error (10170): Verilog HDL syntax error at clock.v(18) near text "else"; expecting "end" Error (10170): Verilog HDL syntax error at clock.v(24) near text "else"; expecting "end"
You can't follow an "else" with an "else if". "else" is a catch-all and means if none of the prior "if" or "else if" statements are true then do what is in the "else". It doesn't make sense to put an "else if" after the "else".
That's what I get for trying to finish a project on an empty stomach. I totally overlooked that. Will fix it and try again. Thanks!
EDIT: Tried the new code, it compiled this time so that's good but I think I made things even worse as far as the clock aspect goes. Will have to look at how to code it again but that shouldn't be a problem. Thanks again.
