17250 Discussions
Using BASE-R PHY IP Megafunction w/ Stratix V
Hi, I am trying to follow this example code in order to create my own verilog design that utilizes BASE-R so that I can use my FPGA's SFP+ transceiver ports:
module gx_link_test_example (
input wire C64453mhz,
input wire C100mhz,
input wire GXB_RXL11,
output wire GXB_TXL11
wire tx_ready;
wire rx_ready;
wire pll_locked;
wire reconfig_busy;
wire [7:0] system_reset_cnt;
reg system_reset=1'b0;
// Reset Counter to give active high reset to enable offset cancellation
counter_128 cnt_128_isnt (
.clock (C100mhz),
.q (system_reset_cnt)
always @ (posedge C100mhz)
begin
if (system_reset_cnt >= 8'd128)
begin
system_reset <= 1'b1;
end
end
low_latency_10g_1ch DUT (
.refclk_in_clk (C64453mhz),
.clk_50_clk (C100mhz),
.refclk_reset_reset_n (system_reset),
.clk_50_reset_reset_n (system_reset),
.xcvr_low_latency_phy_0_tx_serial_data_export (GXB_TXL11),
.xcvr_low_latency_phy_0_rx_serial_data_export (GXB_RXL11),
.xcvr_low_latency_phy_0_tx_ready_export (tx_ready),
.xcvr_low_latency_phy_0_rx_ready_export (rx_ready),
.xcvr_low_latency_phy_0_pll_locked_export (pll_locked),
.alt_xcvr_reconfig_0_reconfig_busy_reconfig_busy (reconfig_busy)
// 1ch passing 30/9/2011
endmodule
However I am not sure what the low_latency_10g_1ch DUT () is doing or how to replicate it for my design since I am new to Quartus and Verilog. Can anyone help me adapt this design to my own?
