VHDL User Library
Hello :
I am in the process of migrating my designs from schematic to VHDL,
and have hit a snag with creating a company library of components. I would
greatly appreciate any help.
I have a number of components that I want to be available for all my
projects. As an example, UnsignedDivide implemented in UnsignedDivide.vhd
with an entity of
ENTITY UnsignedDivide IS
GENERIC ( NW : POSITIVE := 32 ; -- Numerator Width
DW : POSITIVE := 16 ; -- Denominator Width
QW : POSITIVE := 16 ); -- Quotient Width
PORT (Clk : IN STD_LOGIC ;
Start : IN STD_LOGIC ;
Num : IN UNSIGNED (NW-1 DOWNTO 0) ;
Den : IN UNSIGNED (DW-1 DOWNTO 0) ;
Done : OUT STD_LOGIC ;
Quo : OUT UNSIGNED (QW-1 DOWNTO 0) );
END ENTITY UnsignedDivide ;
If I include this file in my project, I can directly instantiate multiple
dividers and they all work fine.
But I want to put all such files in a library and not have to include them
in each project source.
This was easy in schematic designs - just add a directory as a library that contained all the BSF, BDF and megawizard generated VHD files and they could just be added to any BDF in my project. i.e. the library was purely source.
So I need to use a package I think.
So, I created MyCompanyLibrary.vhd that contains :
PACKAGE MyCompanyLibrary IS
COMPONENT UnsignedDivide IS
END COMPONENT UnsignedDivide ;
-- etc
END PACKAGE MyCompanyLibrary ;
I cannot find how to progress from here.
I am hoping to do something like this at the top of all my VHD project files
LIBRARY IEEE ;
USE IEEE.STD_LOGIC_1164.ALL ;
USE IEEE.NUMERIC_STD.ALL ;
LIBRARY MYLIB ;
USE MYLIB.MyCompanyLibrary.ALL
I can make this work in ModelSim by mapping a library MYLIB in my project,
and pre-compiling all the VHD of my library (the pkg file and the
entity/architecture files) into this.
I have been searching the Quartus help for hours now and can't find what I'm looking for.
Any help will be appreciated.
Gary
Your library gets compiled into 'work' by default with quartus. There may be a way to link certain files into a library but it's really just semantics by that point.
library work ; use work.mycompanylib.unsigneddivide ;Alternatively, you can use 'all' or if you didn't really care about the component, you could instantiate the entity directly:
U_unsigned_divide : entity work.unsigneddivide(archname) port map ( ... ) ;Does this help out?
Thanks for your help.
Doing as you suggest still seems to require me adding unsigneddivide.vhd (or the vhdl file containing the PACKAGE declaration) as a PROJECT source file.
If I explicitly add these files, then other files that directly instance unsigneddivide, or instance the component, compile OK.
If I delete the files from the project I get "Error (10481): VHDL Use Clause error at TopLevel_TwoDividers.vhd(73): design library "work" does not contain primary unit "olvUnsignedDivide", even though the directory that contains the source file is specified as a project library.
This is what I am trying to achieve, specifiying a library that contains all my pre-written and debugged library stuff, without having to add each source file to the project I'm working on.
This works fine when synthesizing a schematic design, the compilation process finds the necessary design files in the specified library directories. It even works fine if I have a parameterized symbol in my schematic called unsigneddivide.bsf - the compilation process finds the VHD file in the specified library and there are no problems.
My apologies if these are dumb questions, I wrote my first line of VHDL this week.
Not dumb questions at all, but I wonder if it's a good design practice to have source files that you rely on not be in the scope of the project? Is there a reason you don't want to explicitly add the files to your project? Do you feel they clutter up your project, or are you just used to not having to specify this?
Yes, clutter is my concern. Comparing with SW development, it's like I don't want to have the source for "sprintf" to be part of my project, I just want to include stdio.h.
It seems that if I include a single VHD file from my library "MyLibPackage.vhd" that contains package MyLib which includes all the component declarations, then use WORK.MyLib.All, compilation will then find the instantiated components in the corresponding VHD files in the library, issuing a warning.
I think this is the approach I will take as I start to implement more VHDL source.
Altera usually adds library pathes to the project, when importing e.g. IP cores and stores the sources in separate directories. But they prefer to explicitely include the design files to the project. Using implicite import (by entity name), you get a danger of mixing up different file versions, I fear.
In the Settings dialogue box, click the "Libraries" Category on the left and you can add global or project specific libraries.
If memory serves me correctly then there was a bug with one of them but I can't remember which one.
Have a play and see what works.
