Hi everyone,
I'm a new user of FPGA. I have 2 LEDs and a clock of 32KHz. So I wanna light up LED1 then light off LED 1 and light up LED2. Im trying to do something in VHDL, but it seems it's nonsense what I've done LIBRARY ieee; USE ieee.std_logic_1164.all; use ieee.numeric_std.all; use IEEE.STD_LOGIC_SIGNED; use IEEE.STD_LOGIC_UNSIGNED; use IEEE.STD_LOGIC_ARITH.ALL; ENTITY TP4LED IS PORT ( clock : IN std_logic; s1: OUT std_logic; s2: OUT std_logic ); END TP4LED; ARCHITECTURE behavior OF TP4LED IS -- fonctionnement d'une bascule D signal count : integer(10 downto 0); BEGIN PROCESS (clock) -- liste de sensibilité BEGIN count <= '0'; s1<='1'; s2<='0'; if(clock'event and clock='1')then count <= count + 1; if (count = '9') then s1<='0'; s2<='1'; count<=0; end if; end if; END PROCESS; END behavior; In addition, I have this mistake that I don't know how to resolve it Error (10380): VHDL error at TP4LED.vhd(24): integer type is used but not declared as an array type I know it might be an easy question. Could anyone help me please thank you very much BoLink Copied
integer is not an array type, so you cannot use it like and array. Your count signal declaration says you want 11 integers. If you wanted a single integer with 11 bits, you should use the unsigned type (before you do this - delete the non-standard std_logic_unsigned/signed and std_logic_arith libraries from your library list - otherwise you're going to get all sorts of conflicts).
You need: signal count : unsigned(10 downto 0); secondly, '9' is a character, not an integer value. change it to if count = 9 then... Finally, do not do assignments outside of the clocked part of the process.
