17252 Discussions
Warning (10335): Unrecognized synthesis attribute "template" at...
When I use Quartus II 8.0 to synthesize the project, the warnings occurs:
Warning (10335): Unrecognized synthesis attribute "template" at src/mss/dmss/tkl3_dmem_dummy_ff.v(53)
I searched "Quartus II Help Version 8.0" and found nothing. How can I fix this?
Thanks in advance.
Maybe I need add some information, the warning points to these lines in the file "src/mss/dmss/tkl3_dmem_dummy_ff.v(53)":
// synopsys template
parameter D_WIDTH = 10;
It seems Quartus cannot recognize "// synopsys template".
It is just a warning not an error. The synthesis process will ignore this "template" directive then this on is not supported by Quartus.
Here you can find a list of supported synthesis directives:
verilog hdl synthesis attributes and directives (http://quartushelp.altera.com/11.1/mergedprojects/hdl/vlog/vlog_file_dir.htm
The only way to get rid of the warning is to remove the line with this unknown synthesis directive in your code.
