This is probably very simple, so simple that it is not in faq or help.
I just generated an instance with MegaWizzard and would like to know what resources this new block uses. Also I would like to see the total resources used by my design so far.Link Copied
You need to compile your project to get that information, as the resource usage can vary with the way you connect your instance to the rest of the project. After a successful compilation, go to the fitter report, "Resource Section", "Resource Utilization by Entity".
