16631 Discussions
Where can I find the Arria PCIe _soft_ IP library in Quartus? (Not PCIe HIP)
BChiw
The PCIe SOFT IP compiler is mentioned here:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pci_express.pdf
Table 1–2. IP Compiler for PCI Express Features (Part 1 of 2) [page 4 of 372]
We need more PCIe ports and the two built-in HIPs are not enough.
Thank you
AnandRaj_S_Intel
BChiw
Hello Anand,
Thank you for the quick reply.
I was not referring to the soft DFE implementation.
What I mean in the PCIe soft IP itself (as opposed to the HIP variant).
It is documented here:
Thanks again,
--barny
AnandRaj_S_Intel
​Hi,
You can select it from IP parameter setting tab under Mega-Wizard .
Shown  in image below
I have used Quartus 17.0 std & from IP catalog search PCI and click on IP.
Mega-Wizard window will open up, under IP parameter setting select ether of hard or soft IP option.
Anand
BChiw
Hello Anand,
Could not find the image mentioned in the last reply.
I am also using Quartus 17. I tried to go to the IP Catalog window and here is what is shown:
Only PCIe HIP is present, no soft IP option. Is there a need to install an optional library?
--barny
AnandRaj_S_Intel
​Hi barny,
"Please do follow the steps mentioned"
Click on the IP which will open Mega-Wizard window and go to parameter setting select ether of hard or soft IP option.
attached image.
Also please check device family supported from table 1-4 of below link
BChiw
Hello Anand,
Thank you for the image. It is very helpful. From you screenshot I see the device selected is Arria II GX. Quartus SW showed the IP compiler for PCI Express after the Arria II device family was installed.
From the document link you provided, looks like support is only for Arria II, Cyclone IV, and Stratix IV. Will there be a version that will support Arria 10 device?
Thank you,
--barny
AnandRaj_S_Intel
Thanks barny,
Post edited.
BChiw
Hello Anand,
Your recent reply (2018.12.31) maybe for another ticket?
Since I did not ask about testbench generation.
Going back to my original question. From the document link you provided:
Looks like support is only for Arria II, Cyclone IV, and Stratix IV. Will there be a version that will support Arria 10 device?
Thank you,
--barny
AnandRaj_S_Intel
Hi Baeny,
Presently we don't have any idea,
PCIe Soft IP implementation is not supported for Arria 10 device.
Anand
BChiw
Hello Anand,
Thank you for this confirmation.
Thank you,
--barny
