17255 Discussions
Why QuartusII sysnthesis tool interpreting this verilog code as a latch?
I have question about the verilog code causing Latch and not flip-flop. Your suggestions are welcome. I can add more register stage to this but that can affect the performance.
I am not sure why the QuartusII synthesis tool is considering
ReqInFifoDataIn[72] a latch and not a flip-flop? ReqInFifoData[72] is
clearly defined as part of synchronous always block. It is getting
used by wTag signal - Here I am anding the D input of the Flip-Flop
and Qn output of the same D flip-flop. The purpose of this is to
generate one clock wide wTag pulse.
input [81:0] RxStreamData0,
wire wTag = RxStreamData0[72] & ~ReqInFifoDataIn[72];
reg [81:0] ReqInFifoDataIn;
always @(posedge AppClk or negedge PcieRstN) begin
if (!PcieRstN) begin
ReqInFifoDataIn <= 96'b0;
ReqInFifoDataValid <= 1'b0;
ReqInFifoDataVal <= 1'b0;
end
else begin
ReqInFifoDataIn[81:0] <= RxStreamData0[81:0];
ReqInFifoDataValid <= RxStreamValid0;
ReqInFifoDataVal <= ReqInFifoRd;
end
end
Have you tried separating your assignment from the declaration? Altera may not be supporting all the system verilog style assignments for synthesis.
like this,
wire wTag;
assign wTag = RxStreamData0[72] & ~ReqInFifoDataIn[72];
input RxStreamData0; reg ReqInFifoDataIn; always @(posedge AppClk or negedge PcieRstN) if (!PcieRstN) begin ReqInFifoDataIn <= 96'b0; ReqInFifoDataValid <= 1'b0; ReqInFifoDataVal <= 1'b0; end else begin ReqInFifoDataIn <= RxStreamData0; ReqInFifoDataValid <= RxStreamValid0; ReqInFifoDataVal <= ReqInFifoRd; end wire wTag; assign wTag = RxStreamData0 & ~ReqInFifoDataIn;
--- Quote Start ---
--- Quote End ---
the reason could be your reset initialization. You are trying to set 96 bit to "0", but your reg vector is only " reg [81:0] ReqInFifoDataIn;"
Kind regards
GPK
J'ai conçu un circuit sous quartus II et je veux le validé par un fichier de données élaborer par un programme en langage C, et récupérer les sorties sous forme d'un fichier text, comment faire?
Sorry, I do not well in French.
