17252 Discussions
Why do I need to use the Nios II Command Shell to run bin2flash
Hi all,
I am trying to automate a download process over jtag and need to run bin2flash and nios2-flash-programmer.
I would like to be able to call these directly but cant seem to figure out how to run these without using the Nios II command shell. Can anyone tell me how I can either call these directly or via python? or at least give me a reason why they MUST be run in this way i.e. whats the difference between the Nios command shell and a classic bash or cmd?
thanks,
Grafne
hi.....
the nios command shell set the paths to quartus/bin nios2/bin and pearl
... you need set pearl i guess.....
cheers
Franz Wagner
Thanks _franz,
SO If I take a 'normal' cmd shell and add these paths to my PATH env var then there is no reason to use the Nios II command shell?
Do you know of any documentation on what paths are defined in the shell that I may have to add to my PATH?
G
hi!!
...i dont know about windows cmd .....but at linux machine is the same bash........ i only run a shell script to set paths .....
look like this
#!/bin/bash# Run this for a Nios II SDK bash shell export LM_LICENSE_FILE=1800@localhost SOPC_KIT_NIOS2=/opt/altera9.1/nios2eds export SOPC_KIT_NIOS2 SOPC_BUILDER_PATH_91=/opt/altera9.1/nios2eds export SOPC_BUILDER_PATH_91 unset GCC_EXEC_PREFIX QUARTUS_ROOTDIR=/opt/altera9.1/quartus export QUARTUS_ROOTDIR export PERL5LIB=/usr/lib/perl/5.10.0 bash --rcfile $QUARTUS_ROOTDIR/sopc_builder/bin/nios_bash
hope i can helped...... sorry but im not familiar with this language.......
cheers
Franz Wagner
Schönen Dank Franz!! :)
A very well answered question!! I have managed to get everything I need to work so far! I was a little nervous as I had been told by a FPGA 'expert' that you MUST use the Altera shell but seems not to be the case.
I now have a python script that completely automates the building of flash files (bin2flash) and downloads to a cyclone IV. One small issue but I will start another thread for it.
Again, thanks for your help!
Grafne
dank grafne......
sound good ......:)
good luck
Franz Wagner
I am trying to use Nios2 command shell, getting an error like No cfi table found. How do i override cfit table?
