17254 Discussions
constant manipulation in VHDL statement
I am puzzled by the result of a VHDL code and hope someone could help understand the problem.
constant PERIOD : integer := 1000;
constant A : integer := 4;
constant B : integer := 23;
process
variable count : integer := 0;
if count < (PERIOD* (A+B )) then
It appears that the behavior of the statement above is not as I expected: "if count < (1000 * (4+23)) then".
1. Where did my 'logic' go wrong?
2. How do I find out how VHDL codes are parsed in Quartus?
Are you simulating or synthesizing? If you write "if count < 27000 then" the code works different?
Please, place the whole vhdl code to understand it better.
Your logic is correct, it should be 27000. Post the whole code.
--- Quote Start ---
--- Quote End ---
I guess I was synthesizing. I compiled the project, download the sof to DE0-NANO to run it.
Here is the VHDL code. Thank you for the help.
LIBRARY ieee; USE ieee.std_logic_1164.all; LIBRARY work; ENTITY square IS PORT ( clk : IN STD_LOGIC; vs: IN STD_LOGIC; -- vertial sync wr_req: OUT STD_LOGIC; -- write request data: OUT STD_LOGIC_VECTOR(7 downto 0) ); END square; ARCHITECTURE bdf_type OF square IS constant HSYNC_PERIOD : integer := 1056; -- LCD horizontal period is 1056 clock cycles constant HSYNC_LOW : integer := 128; -- LCD horizontal sync signal pulse width is 128 LCD clock cycles constant H_FRONT_PORCH : integer := 64; -- Horizontal front porch = 64 pixels constant H_BACK_PORCH : integer := 64; -- Horizontal back porch = 64 pixels constant H_PIXELS : integer := 800; -- Horizontal display period = 800 pixels constant VSYNC_PERIOD : integer := 666 * HSYNC_PERIOD; -- LCD vertical period is 666 horizontal line constant VSYNC_LOW : integer := 4 * HSYNC_PERIOD; -- LCD vertical sync signal pulse width is 4 horizontal lines constant V_FRONT_PORCH : integer := 39 * HSYNC_PERIOD; -- Vertical front porch = 39 lines constant V_BACK_PORCH : integer := 23 * HSYNC_PERIOD; -- Vertical back porch = 23 lines constant V_LINES : integer := 600 * HSYNC_PERIOD; -- Vertical display period = 600 lines constant RED : STD_LOGIC_VECTOR(7 downto 0) := x"0a"; constant GREEN : STD_LOGIC_VECTOR(7 downto 0) := x"0b"; constant YELLOW : STD_LOGIC_VECTOR(7 downto 0) := x"0c"; constant BLUE : STD_LOGIC_VECTOR(7 downto 0) := x"0d"; constant PURPLE : STD_LOGIC_VECTOR(7 downto 0) := x"0e"; constant TURQUOISE : STD_LOGIC_VECTOR(7 downto 0) := x"0f"; constant WHITE : STD_LOGIC_VECTOR(7 downto 0) := x"10"; constant PIXEL_OFF : STD_LOGIC_VECTOR(7 downto 0) := x"01"; BEGIN -- Input: -- none -- Clock: -- LCDclk - LCD clock @ 10 MHz -- Output: -- LCDHsyncN - signal, LCD horizontal timing -- Description: -- This process generates LCD horizontal timing signal: 480 clock cycles high and 128 clock cycles low PROCESS(clk, vs) variable p_count : integer range 0 to H_PIXELS; variable clk_count : integer := 0; BEGIN if rising_edge(clk) then if vs = '0' then -- clk_count := ((HSYNC_PERIOD * VSYNC_LOW) - 1); -- Vertical sync pulse width is 4 lines clk_count := (1056*4) - 1; -- Vertical sync pulse width is 4 lines wr_req <= '0'; else clk_count := clk_count + 1; -- if clk_count < (HSYNC_PERIOD * (VSYNC_LOW+V_BACK_PORCH)) then if clk_count < (1056 * (4+23)) then -- vertical blank period; do nothing p_count := 0; wr_req <= '0'; -- elsif clk_count < (HSYNC_PERIOD * (VSYNC_LOW+V_BACK_PORCH+1)) then elsif clk_count < (1056 * (4+23+1)) then -- 1st display line -- if clk_count = (HSYNC_PERIOD * (VSYNC_LOW+V_BACK_PORCH)) then if clk_count = (1056 * (4+23)) then -- 1st pixel of the line p_count := 0; -- reset pixel count wr_req <= '1'; -- elsif clk_count < ((HSYNC_PERIOD * (VSYNC_LOW+V_BACK_PORCH)) + H_PIXELS) then elsif clk_count < ((1056 * (4+23)) + 800) then data <= GREEN; wr_req <= '1'; else wr_req <= '0'; data <= PIXEL_OFF; end if; else data <= PIXEL_OFF; wr_req <= '0'; end if; end if; end if; END PROCESS; END bdf_type;
Listed below is the complete code. "if clk_count < (1056 * (4+23))" works but "if clk_count < (HSYNC_PERIOD * (VSYNC_LOW+V_BACK_PORCH))" does not.
LIBRARY ieee; USE ieee.std_logic_1164.all; LIBRARY work; ENTITY square IS PORT ( clk : IN STD_LOGIC; vs: IN STD_LOGIC; -- vertial sync wr_req: OUT STD_LOGIC; -- write request data: OUT STD_LOGIC_VECTOR(7 downto 0) ); END square; ARCHITECTURE bdf_type OF square IS constant HSYNC_PERIOD : integer := 1056; -- LCD horizontal period is 1056 clock cycles constant HSYNC_LOW : integer := 128; -- LCD horizontal sync signal pulse width is 128 LCD clock cycles constant H_FRONT_PORCH : integer := 64; -- Horizontal front porch = 64 pixels constant H_BACK_PORCH : integer := 64; -- Horizontal back porch = 64 pixels constant H_PIXELS : integer := 800; -- Horizontal display period = 800 pixels -- constant DPL_LINES : integer := 234; -- each LCD display frame consists of 234 horizontal lines -- constant FB_LINES : integer := 28; -- LCD vertical flyback period is 28 horizontal line constant VSYNC_PERIOD : integer := 666 * HSYNC_PERIOD; -- LCD vertical period is 666 horizontal line constant VSYNC_LOW : integer := 4 * HSYNC_PERIOD; -- LCD vertical sync signal pulse width is 4 horizontal lines constant V_FRONT_PORCH : integer := 39 * HSYNC_PERIOD; -- Vertical front porch = 39 lines constant V_BACK_PORCH : integer := 23 * HSYNC_PERIOD; -- Vertical back porch = 23 lines constant V_LINES : integer := 600 * HSYNC_PERIOD; -- Vertical display period = 600 lines constant RED : STD_LOGIC_VECTOR(7 downto 0) := x"0a"; constant GREEN : STD_LOGIC_VECTOR(7 downto 0) := x"0b"; constant YELLOW : STD_LOGIC_VECTOR(7 downto 0) := x"0c"; constant BLUE : STD_LOGIC_VECTOR(7 downto 0) := x"0d"; constant PURPLE : STD_LOGIC_VECTOR(7 downto 0) := x"0e"; constant TURQUOISE : STD_LOGIC_VECTOR(7 downto 0) := x"0f"; constant WHITE : STD_LOGIC_VECTOR(7 downto 0) := x"10"; constant PIXEL_OFF : STD_LOGIC_VECTOR(7 downto 0) := x"01"; BEGIN -- Input: -- none -- Clock: -- LCDclk - LCD clock @ 10 MHz -- Output: -- LCDHsyncN - signal, LCD horizontal timing -- Description: -- This process generates LCD horizontal timing signal: 480 clock cycles high and 128 clock cycles low PROCESS(clk, vs) variable p_count : integer range 0 to H_PIXELS; variable clk_count : integer := 0; BEGIN if rising_edge(clk) then if vs = '0' then -- clk_count := ((HSYNC_PERIOD * VSYNC_LOW) - 1); -- Vertical sync pulse width is 4 lines clk_count := (1056*4) - 1; -- Vertical sync pulse width is 4 lines wr_req <= '0'; else clk_count := clk_count + 1; -- if clk_count < (HSYNC_PERIOD * (VSYNC_LOW+V_BACK_PORCH)) then if clk_count < (1056 * (4+23)) then -- vertical blank period; do nothing p_count := 0; wr_req <= '0'; -- elsif clk_count < (HSYNC_PERIOD * (VSYNC_LOW+V_BACK_PORCH+1)) then elsif clk_count < (1056 * (4+23+1)) then -- 1st display line -- if clk_count = (HSYNC_PERIOD * (VSYNC_LOW+V_BACK_PORCH)) then if clk_count = (1056 * (4+23)) then -- 1st pixel of the line p_count := 0; -- reset pixel count wr_req <= '1'; -- elsif clk_count < ((HSYNC_PERIOD * (VSYNC_LOW+V_BACK_PORCH)) + H_PIXELS) then elsif clk_count < ((1056 * (4+23)) + 800) then data <= GREEN; wr_req <= '1'; else wr_req <= '0'; data <= PIXEL_OFF; end if; else data <= PIXEL_OFF; wr_req <= '0'; end if; end if; end if; END PROCESS; END bdf_type;
VSYNC_LOW and V_BACK_PORCH are respectively defined as 4 * HSYNC_PERIOD and 23 * HSYNC_PERIOD, so (1056 * (4+23)) and (HSYNC_PERIOD * (VSYNC_LOW+V_BACK_PORCH)) are far from equal. I assume you meant just (VSYNC_LOW+V_BACK_PORCH) as a comparison value.
duh ... Thank you for the help.
This kind of mistake happens to anyone ;)
But this shows how important it is to give all your code when you are encountering a strange problem and ask for help!
