I have a itterative fn to aproximate a square root the 8 bit value
root_x = 0 initially and 0111_0000 when the input x is 49 ie 0111_0000 = 7.0 (so for 51 ~ 7.12). When I run the below wrapper module I always get 0 for root_x[7:4] and root_x[3:0] since they dont get the correct answer until as few itterations 150ns latter any Idea how I would sample these 2 values at 150ns ? module extra(clk, x,increment,root_x, MSD, LSD, f0, f1,compute,num,num1); input [7:0] x; input clk, compute; output [10:0] increment; output [7:0] root_x,num,num1; reg [7:0] num,num1; output [6:0] MSD, LSD, f0, f1; wire [7:0] root_x; sqrt sq (clk, x, root_x, increment,p1,p2); always @ * begin //p2 = root_x[7:4]; //p1 = root_x[3:0]; if (compute) begin num = {4'b000, root_x[7:4]}; case (root_x[3:0]) 4'b0000: num1=8'd0; 4'b0001: num1=8'd6; 4'b0010: num1=8'd12; 4'b0011: num1=8'd18; 4'b0100: num1=8'd25; 4'b0101: num1=8'd32; 4'b0110: num1=8'd37; 4'b0111: num1=8'd43; 4'b1000: num1=8'd50; 4'b1001: num1=8'd56; 4'b1010: num1=8'd62; 4'b1011: num1=8'd68; 4'b1100: num1=8'd75; 4'b1101: num1=8'd81; 4'b1110: num1=8'd87; 4'b1111: num1=8'd93; endcase end else num = x; end ss_display SSD (num, MSD, LSD); ss_display SSD1 (num1, f0, f1); endmodule `include "sqrt.v" `include "ss_display.v"Link Copied
