no sof file
I am using Quartus II 8.1 für Linux. I am compiling a simple project, the compilation is done and I cannot programm the device, because there is no sof file. I cannot find the sof file. I searched the entire PC, but nothing. Thanks.
this problem might be due to the invalid license, check your license first
You may want to check for any errors/warnings in the Compilation Report Assembler section
You can view this with the Processing Menu->Compilation Report
Expand the Assembler section and click on messages.
A Sof file should always be produced and will be in the top level of your project directory.
Just another thought....
Have you made sure that the device you have selected is installed in your version of Quartus.
For example, Web Edition only supports a subset of devices although it may allow compilation for others but will not produce an output file.
--- Quote Start ---
--- Quote End ---
there are no errors in compilation
Info: Quartus II Full Compilation was successful. 0 errors, 258 warning
I am still using a trial. I do not have a license jet.
I do not understand about the device, which device do you mean. For Linuix there is no Web Edition
--- Quote Start ---
--- Quote End ---
that is it, thank you
Warning: Can't generate programming files because you are currently using the Quartus II software in Evaluation Mod
