pwm verilog code
please help me to fnd pwm Verilog code
thank yu
check this out !
http://www.ece301.com/fpga-projects/53-pwm.html
REMEMBER : google is your best friend :)
I would like to know whether attached code is right to generate pwm wave.
please reply
Your code will generate a wave that looks like a PWM !
To create a PWM you need a duty cycle (how often do you want to refresh your signal) : You need to know your board frequency and compute the duty of your PWM ...
The link I gave you explain that ! Follow the steps and stop jumping into coding something you don't understand
I recommend you read the page carefully
I hope this idea is correct.
my fpga clock is 50mhz.that is period 20ns.
I designed a pwm with 1000ns period.
switch variable given as 2 to get 80 percent duty cycle.
please check.
Thankyou
1000 ns =>
P = 0.000001*50000000 = 50
SC (Steps Count) = 2^3 = 8
==> sd = P / SC = 50/8 =6.25
but you are using sd = 20 !
Please read carefully the page (link I posted) and follow the steps ! It's not that hard !
what is mean by refreshing signal?? I didn't get. can't i take p=1000ns?
by refreshing signal we mean the time we need to have a new value (period)
Yes you can take whatever period you want ! For 1000 ns P = 50 (because you multiply the 20 ns by 50 to get 1000 ns)
