17268 Discussions
'quartus_pgm' command - works with "Nios II Command Shell" but not with batch file
Amir3
Hey everyone,
I'm trying to burn Flash memory device (MT25QL256) with SW image (Nios Application) by Batch file with these commands, and always I get an error:
C:\intelFPGA_lite\18.0\quartus\bin64\quartus_pgm --nios2 --epcq --base=0xY --csr=0xZ --cable="USB-Blaster [USB-2]" X.flash
This Batch file located in the same path of "X.flash" file.
When I'm trying to burn Flash memory device with "Nios II Command Shell 18.0" tool with these commands, It's work:
1. cd Path
2. quartus_pgm --nios2 --epcq --base=0xY --csr=0xZ --cable="USB-Blaster [USB-2]" X.flash
The 'quartus_pgm' command is the same in both scenarios, so I don't understand why it doesn't work with the Batch file.
Note - PathX, Y and Z have no special meaning, I can't write down the original data.
Thenks.
KellyJialin_Goh
The Programmer uses these valid supported file formats: Programmer Object Files (.pof), SRAM Object Files (.sof), Jam File (.jam), or Jam Byte-Code File (.jbc).
However, the command line quartus_pgm.exe can run in batch file where it reads the file and executes the command. Hope this could solve your issue.
Thank you.
Kelly Jialin
Amir3
I'm sorry, but I don't understand how your answer help me..
As I mentioned, the 'quartus_pgm' command works in the "Nios II Command Shell 18.0" tool but not through the Batch file.
The Batch file stores in the same Path as the other relevant files (X.flash and more).
If it helps, the command I use to convert an elf file to a flash file:
elf2flash --verbose --input=A.elf --output=X.flash --base=0xY --end=0xC --reset=0xB --boot=${SOPC_KIT_NIOS2}/components/altera_nios2/boot_loader_cfi.srec
NotePathXYZ, A, B and C have no special meaning, I can't write down the original data.
KellyJialin_Goh
Is the information provided useful to you?
Kelly Jialin
KellyJialin_Goh
As we do not receive any response from you on the previous reply that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
Kelly Jialin, GOH
KellyJialin_Goh
Could you kindly log in to ‘https://supporttickets.intel.com’ to reopen this case so that I can support your question further.
Thank you.
Kelly Jialin, GOH
Amir3
Hey Kelly,
This case has been reopened, I would appreciate your help.
KellyJialin_Goh
The 'quartus_pgm' command cannot be used as it does not support a batch file, but 'quartus_pgm.exe' can run in batch file where it reads the file and executes the command.
Here is some information that might be useful to you: https://www.intel.com/content/www/us/en/docs/programmable/683118/current/quartus-pgm-nios2.html
You can also look at the elf2flash section from the link above.
Kelly
Amir3
Hey Kelly,
I don't see any problem with my 'quartus_pgm' and 'elf2flash' commands.
In addition, using the "Nios II Command Shell 18.0" tool, if something was not correct in the above commands, probably the programming and functioning of the system would not work either.
Do you have another way to help me?
KellyJialin_Goh
Could you share your .bat file for reference?
You can also adjust the path:
C:\intelFPGA_lite\18.0\quartus\bin64\quartus_pgm --nios2 --epcq --base=0xY --csr=0xZ --cable="USB-Blaster [USB-2]" <path to X.flash file>.flash
Thank you.
Kelly
Amir3
Hey Kelly,
The Batch file:
pause
Remminde you the Batch file stores in the same Path as the other relevant files (X.flash and more).
KellyJialin_Goh
Is the X.Flash in the path of C:\intelFPGA_lite\18.0\quartus\bin64\quartus_pgm?
Are they in the same directory with the quartus_pgm executable? If no, could you copy the X.flash in the same directory as the quartus_pgm.
Thank you.
Kelly
Amir3
Hey Kelly,
The Batch file in the same directory of the X.flash, for example:
- Flash file directory - Path/X.flash.
- Batch file directory - Path/Burn.bat.
Do you want me to move the Flash file and Batch file to the path of quartus_pgm application? (C:\intelFPGA_lite\18.0\quartus\bin64\quartus_pgm)
KellyJialin_Goh
Yes, move the flash file to the same directory as quartus_pgm but remain the batch file in the directory :
Hope this helps. Thank you.
Kelly
Amir3
Hey Kelly,
If I understand you correctly, the paths should be in this order:
- Flash file directory - C:\intelFPGA_lite\18.0\quartus\bin64\X.flash.
- Batch file directory - C:\intelFPGA_lite\18.0\quartus\bin64\Burn.bat.
- Quartus_pgm application directory - C:\intelFPGA_lite\18.0\quartus\bin64\quartus_pgm.exe.
And the text in the Batch file should be:
pause
I'd appreciate your confirmation.
KellyJialin_Goh
Yes, correct. Does your .bat file run with 'quartus_pgm' command now?
Thank you.
Kelly
KellyJialin_Goh
Any updates from your side?
Kelly
KellyJialin_Goh
As we do not receive any response from you on the previous answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you.
Kelly Jialin, GOH
