17255 Discussions
question about writing testbench
Hi all,
I wrote a testbench for a full adder. However, the testbench doesnt work. The function of the testbench is, that it tries to read input stimulis from a file called fa_in.txt and output results to a file called fa_out.txt. The error is, that entity fa wrote nothing to output file fa_out.txt, and there is no any waveform in Modelsim editor. The input file looks like:
----file begins----
000
001
010
011
100
101
110
111
----file ends----
after simulation, the output file should looks like:
---file begins----
1.000---->00
2.001---->01
3.010---->01
4.011---->10
5.100---->01
6.101---->10
7.110---->10
8.111---->11
---file ends----
Can anybody shed some light on my code? Thanks.
----VHDL code for full adder----
library IEEE;
use IEEE.STD_LOGIC_1164.all;
entity fa is
port( CIN,A,B:in BIT;
COUT,SUM: out BIT);
end fa;
architecture fa_behavior of fa is
begin
process(CIN,A,B
variable TEMP_COUT,TEMP_SUM:BIT;
begin
case CIN&A&B is
when "000" =>TEMP_COUT:='0';TEMP_SUM:='0';
when "001" =>TEMP_COUT:='0';TEMP_SUM:='1';
when "010" =>TEMP_COUT:='0';TEMP_SUM:='1';
when "011" =>TEMP_COUT:='1';TEMP_SUM:='0';
when "100" =>TEMP_COUT:='0';TEMP_SUM:='1';
when "101" =>TEMP_COUT:='1';TEMP_SUM:='0';
when "110" =>TEMP_COUT:='1';TEMP_SUM:='0';
when "111" =>TEMP_COUT:='1';TEMP_SUM:='1';
end case;
COUT<=TEMP_COUT;SUM<=TEMP_SUM;
end process;
end fa_behavior;
----VHDL code ends----
----testbench code----
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use STD.TEXTIO.all;
entity TB_fa is end;
architecture IO_EXAMPLE of TB_fa is
component fa
port (CIN,A,B:in BIT;COUT,SUM: out BIT);
end component;
file VEC_FILE:TEXT
open READ_MODE is "c:/fa/fa_in.txt";
file RESULT_FILE:TEXT
open WRITE_MODE is "c:/fa/fa_out.txt";
signal S: BIT_VECTOR(0 to 2);
signal Q: BIT_VECTOR(0 to 1);
begin
TB_fa: fa port map (S(0),S(1),S(2),Q(0),Q(1));
process
constant PROPAGATION_DELAY:TIME:= 2 ns;
variable BUF_IN,BUF_OUT:LINE;
variable OUT_STR:BIT_VECTOR(0 to 1);
variable NUM_VECTORS:INTEGER:=0;
variable VAR_S:BIT_VECTOR(0 to 2);
begin
while not ENDFILE (VEC_FILE) loop
READLINE(VEC_FILE,BUF_IN);
assert(BUF_IN'LENGTH=3)
report "Vector does not have three bits"
severity ERROR;
READ(BUF_IN,VAR_S);
S<=VAR_S;
wait for PROPAGATION_DELAY;
NUM_VECTORS:=NUM_VECTORS+1;
WRITE(BUF_OUT,NUM_VECTORS);
WRITE(BUF_OUT,STRING'("."));
WRITE(BUF_OUT,S);
WRITE(BUF_OUT,STRING'("---->"));
OUT_STR:=Q;
WRITE(BUF_OUT,OUT_STR);
WRITELINE(RESULT_FILE,BUF_OUT);
end loop;
report "Completed processing all vectors.";
wait;
end process;
end IO_EXAMPLE;
----testbench code ends----
you didnt say what the error is.
But I would suggest having separate processes for input and output.
--- Quote Start ---
--- Quote End ---
The error is, that the full adder entity didnt write anything to output file fa_out.txt, and there is no any waveforms in Modelsim editor.
once you fix the syntax error, it works perfectly fine for me.
