17258 Discussions
the connection of multiple modules
module LED(clk_div320k,rst,out,common1,common2,common3,common4,BCD_hunds,BCD_tens,BCD_units);
input clk_div320k,rst,BCD_hunds,BCD_tens,BCD_units;
output reg [6:0]out;
output reg common1,common2,common3,common4;
reg [1:0] state , next_state;
parameter s1=2'b01,s2=2'b01,s3=2'b10,s4=2'b11;
divide_320k h1(.clk_div320k(clk_div320k),.rst(rst));
Binary_turn_BCD h2(.BCD_hunds(BCD_hunds),.BCD_tens(BCD_tens),.BCD_units(BCD_units));
I want to know how to combine two modules by a parallel method(like A->B->C)
I think I use the wrong way , like A(B)or B(C)
the compilation result has two types,
if I ignore the red program , it tells me cannot be assign more than one value
and if i ignore blue program, the compilation will be success , but there will be a lot of warming
below this program is state machine, but i think the fault is not in the state machine
sorry my english is not pretty good
always@(posedge clk_div320k)
begin
if(rst)
state <= s1;
else
state <= next_state;
end
always@(*)
begin
case(state)
s1:next_state=s2;
s2:next_state=s3;
s3:next_state=s4;
s4:next_state=s1;
default:next_state=s1;
endcase
end
begin
case(state)
s1:
begin
common1=1'b1;common2=1'b0;common3=1'b0;common4=1'b0;
case(BCD_units)
4'b0000: out=7'b1000000;
4'b0001: out=7'b1111001;
4'b0010: out=7'b0100100;
4'b0011: out=7'b0110000;
4'b0100: out=7'b0011001;
4'b0101: out=7'b0010010;
4'b0110: out=7'b0000010;
4'b0111: out=7'b1111000;
4'b1000: out=7'b0000000;
4'b1001: out=7'b0010000;
endcase
end
s2:
begin
common2=1'b1;common1=1'b0;common3=1'b0;common4=1'b0;
case(BCD_tens)
endcase
end
s3:
begin
common3=1'b1;common1=1'b0;common2=1'b0;common4=1'b0;
case(BCD_hunds)
4'b00: out=7'b1000000;
4'b01: out=7'b1111001;
4'b10: out=7'b0100100;
4'b11: out=7'b0110000;
endcase
end
s4:
begin
common4=1'b1;common1=1'b0;common2=1'b0;common3=1'b0;
out=7'b1111111;
end
default: out=7'b1111111;
endcase
end
endmodule
parallel
Refer to a very good article covering this - "verilog: how to instantiate a module (http://stackoverflow.com/questions/20066850/verilog-how-to-instantiate-a-module)".
You can also look at "verilog hdl syntax and semantics (http://www.asic-world.com/verilog/syntax2.html)".
Cheers,
Alex
