17056 Discussions
trouble with Quartus II error
i write a testbench for a decoder but when i compile this file in quartus,this error comes out.
error: can't synthesize current design -- top partition does not contain any logic
but the same design files can be compiled in modelsim successfully.
who can tell me why? how to solve it?
--- Quote Start ---
--- Quote End ---
did you try to synthesize the testbench ? The testbench has no inputs or outputs. I expect
that Quartus will remove all your logic, because no output depends on an input. A Testbench is only used for simulation.
Kind regards
GPK
--- Quote Start ---
Kind regards
GPK
--- Quote End ---
thank you very much! now i knows.
