Intel® QuickAssist Technology (Intel® QAT)
For questions and discussions related to Intel® QuickAssist Technology (Intel® QAT).
95 Discussions
FreeBSD QAT - Only 2 instances, why?
JamesElstone
Hi All,
First time poster here, but looking for some help please.
I want to know why FreeBSD is locked to only use two (2) engines / instances, whereas the hardware I have can support up to 12 instances/engines?
E.G. only 2/12 engines are being used, whereas the remaining 10/12 sit idle, and no interrupts occur.
Can anyone let me know if this is a limitation within the Intel QAT driver or is a limitation in the way FreeBSD implement the QAT driver into their CryptoDev framework please?
James.
Ronny_G_Intel
Hi James,
Thanks for reaching out to Intel Communities.
It may be possible that you only have 2 QAT devices bound to a process. Please run the following commands to better understand the current situation:
$ lsmod | grep qat
$ adf_ctl status
$ lspci -k | grep -A 3 QAT
It will also be beneficial to understand how QAT was configured and what kind of work QAT is doing. Please provide me with the details.
Ronny G
Ronny_G_Intel
Hi James,
I am just checking if you have any update regarding this issue.
Ronny G
Ronny_G_Intel
Hi James,
I am just following up on this issue.
If there are no updates, I will proceed to close the internal ticket we created for it.
Please let me know.
Ronny G
Ronny_G_Intel
Hi James,
I haven't heard back from you in a while, so I am closing the internal ticket we created for this issue. If you need further assistance, please feel free to create a new community post.
Ronny G
