Intel® QuickAssist Technology (Intel® QAT)
For questions and discussions related to Intel® QuickAssist Technology (Intel® QAT).
94 Discussions
How do I confirm if my QAT device supports compression?
xuqing
How do I confirm if my QAT device supports compression? My device uses the 200xx driver and the CPU is https://www.intel.com/content/www/us/en/products/sku/226114/intel-xeon-d1734nt-processor-15m-cache-up-to-3-10-ghz/specifications.html
Ronny_G_Intel
Hi xuqing,
You may refer to the following article applicable for Intel® Xeon® D-2700 and D-1700 processors: https://www.intel.com/content/www/us/en/products/docs/processors/xeon-d/network-segments-product-brief.html
Intel® QuickAssist Technology (Intel® QAT) with inline IPSec support accelerates encryption and compression; the platform is capable of driving up to 100 Gbps crypto and 70 Gbps compression. The crypto capability also includes inline IPSec, which enables customers to free up precious compute cores for other applications.
Let me know if you need further information.
Ronny G
xuqing
Hi Ronny G,
However, when I use dpdk to search for devices (the command is dpdk/usertools/dpdk-devbind.py --status), I can find encryption devices but not compression devices. My dpdk version is v23.11. I want to ask if some configuration (such as specific firmware) is required to use compression devices, or if my QAT device does not support compression?
xuqing
xuqing
Also, when I was doing performance testing, I found that the encryption device also could not reach 100Gbps, the highest was only 32Gpbs, is this correct?
Ronny_G_Intel
Hi xuqing,
I would recommend that you use cpa_sample_code instead of DPDK (DPDK is focused in providing high-performance packet processing frameworks for building software-defined networking and network function virtualization applications, not really into compression).
Please refer to the following website for cpa_sample_code details:
https://intel.github.io/quickassist/GSG/2.X/sampleapplications.html#performance-sample-code
Note: Before running cpa_sample_code make sure QAT is properly configured, refer to:
https://intel.github.io/quickassist/GSG/2.X/installation.html
On the other hand, how are you testing encryption device performance? And, what are you using as a benchmark for your results? Can you share the environment details?
Ronny G
Ronny_G_Intel
Hi xuqing,
I am just checking if you had a chance to check into in my previous note and try cpa_sample_code instead of DPDK.
Please let me know.
Ronny G
xuqing
Hi Ronny,
Thank you very much for your reply. I have tried cpa_sample_code and found that it can support compression. As for crypto performance testing, I used dpdk-test-crypto-perf  for testing before, and my CPU information is as follows, and my QAT device driver is 200xx.
The dpdk commands used for the test are as follows, In this command I used two VFs and one DPDK worker thread.
${dpdk_dir}/build/app/dpdk-test-crypto-perf --socket-mem 2048,0 --legacy-mem -a 0000:01:01.0 -a 0000:01:02.0 -l 1,6 -n 4 -- --buffer-sz 64,128,256,512,1024,2048,4096,8192,16384 --optype cipher-only --ptest throughput --cipher-key-sz 64 --devtype crypto_qat --auth-op generate --burst-sz 32 --total-ops 30000000 --silent --digest-sz 20 --cipher-algo aes-xts --cipher-op encrypt
The test results are shown in the figure below, and maximum bandwidth is about 32Gbps.
And when I tested it with cpa_sample_code, the encrypted bandwidth for 4K was 27730Mbps, which is much less than 100Gbps.
Best Regards.
xuqing
Ronny_G_Intel
Hi xuqing,
Can you please provide with the whole cpa_sample_code report?
Can you also let me know if you are using any particular QAT configuration?
Ronny G
xuqing
Hi Ronny G,
I didn't use any particular QAT configuration.The cpa_smaple_result.txt is the whole cpa_sample_code report, and I only run symmetric code tests(cpa_sample_code runTests=1).
200xx_dev0.txt is the configuration file for the QAT device.
xuqing
Ronny_G_Intel
Hi xuqing,
Thank you for sending the information I requested. After reviewing the cpa_sample_results.txt and 200xx_dev0.txt files, everything appears to be in order. I attempted to find a comparable system within our resources to conduct a parallel assessment, but I was unable to find similar hardware to replicate the results.
To my knowledge, we do not have a standardized QAT performance matrix or benchmarking reference available. Could you please clarify what benchmarks or documentation you are using to evaluate your results? Are these performance metrics tailored to your specific QAT device, or are they based on general processor performance data?
Additionally, I suggest consulting our Performance Optimization Guide for further insights. You can find it at https://intel.github.io/quickassist/PERF/index.html. This guide may provide valuable information on how to optimize the performance of your QAT device.
Ronny G
Ronny_G_Intel
Hi xuqing,
Did you have a chance to check on my previous note?
Please let me know if you need additional assistance.
Ronny G
Ronny_G_Intel
Hi xuqing,
I hope that you are doing well.
I haven't gotten any update from you regarding this post, so I will be closing the internal ticket automatically generated for this issue. Please feel free to reopen or create a new one if you still need assistance.
regards,
Ronny G
