Intel® QuickAssist Technology (Intel® QAT)
For questions and discussions related to Intel® QuickAssist Technology (Intel® QAT).
97 Discussions
SPI Flash Image Inquiry for QAT PCIe x8 3.0 Card Using Intel C627 in Endpoint Mode
jungsoolim
We are developing a QAT-only PCIe x8 3.0 card operating in Endpoint mode, using the Intel C627 chipset. Could you please advise which image should be used in the SPI Flash for this configuration?
System Summary:
  • Chipset: Intel C627
  • Mode: Endpoint mode
  • Function: QAT only
  • Interface: PCIe x8 3.0 card
Ronny_G_Intel
Hi Jungsoo,
I have found the internal repository where we store the SPI Flash images, but these are intended for internal use only. I am currently figuring out how to share them with an external customer. To move forward, I have created an IPS ticket, and you should have received an email notification about it. Could you please check and confirm whether you have access to view the ticket I created?
Ronny G
Ronny_G_Intel
Hi jungsoolim,
I am currently checking with the QAT team and I will get back to you as soon as possible.
Ronny G
jungsoolim
Dear Ronny,
Thank you for your message and for checking with the QAT team.
I just wanted to kindly follow up to see if there have been any updates or progress since your last reply.
Your support is much appreciated, and I look forward to hearing from you.
Jungsoo Lim
Ronny_G_Intel
Hi Jungsoo,
Ronny G
jungsoolim
Hi Ronny,
Thanks for the update.
It seems there might be an issue with the email notification, as I didn’t receive it.
However, I was able to log into IPS with my Intel account and confirm that I can access Ticket Case Number 00959009 without any problems.
Let me know if there’s anything else I should do on my end.
Jungsoo
Ronny_G_Intel
Hi Jungsoo,
Could you please confirm the platform you intend to use?
If I understand correctly, you are requesting the SPI Flash Image for the QAT PCIe x8 3.0 Card utilizing the Intel C627 in EPO Mode.
This suggests you will be using the PCH from Purley on an QAT add-in card, as there is no CPU directly connected to the PCH.
Consequently, this setup would be limited to the initial Lewisburg PCH SKUs, such as the C627 you mentioned.
If this is accurate, please note that this was launched in Q3 2017, which is 8 years ago, and regular support typically ends after 7 years.
Therefore, obtaining the requested SPI Flash Image may be challenging and cant promise anything at this point.
Ronny G
Ronny_G_Intel
Hi Jungsoo,
I am still trying to get the SPI Flash Image for QAT PCIe x8 3.0 Card Using Intel C627 in Endpoint Mode, unfortunately support for it ended last year.
Could you provide me with a quick evaluation of the potential consequences if we are unable to supply this image? I need this information to escalate the request.
Ronny G
jungsoolim
Hi Ronny,
Thank you for following up.
We have previously used the Intel DH8950 for our QAT (QuickAssist Technology) development. Due to its discontinuation, we have been considering the Intel C627 as an alternative. As far as we understand, the C627 is still in production and there are currently no plans for discontinuation.
However, if we are unable to obtain the SPI Flash image for the C627 in Endpoint Mode, we will be forced to cancel our current development plans. This would require us to explore and evaluate third-party accelerator chips outside the Intel ecosystem, which presents a significant shift in both engineering effort and risk.
Given our team’s experience and long-term familiarity with Intel QAT solutions, we strongly prefer to continue development with Intel-provided chips.
We would appreciate it if you could check whether there is **any other way** to obtain the required SPI Flash image for the C627 in Endpoint Mode, despite the official end of support.
Your support would be highly valuable in helping us avoid a disruptive change in our roadmap.
Jungsoo
Ronny_G_Intel
Hi Jungsoo,
Thank you for sharing all these details; I'm using this information to support your request. I'm doing my best to obtain the SPI Flash Image for you. If I succeed, I'll make the file accessible through IPS, but please note that it will come without any support.
Ronny G
Ronny_G_Intel
Hi Jungsoo,
I am closing this case as we are addressing the request through IPS.
I anticipate having a definitive answer for you by the end of this week.
Ronny G
jungsoolim
Dear Ronny,
Thank you for the update.
I understand that the case is being addressed through IPS, and I will await a definitive response by the end of this week as anticipated.
I truly appreciate your continued support and assistance.
Jungsoo
