Intel® QuickAssist Technology (Intel® QAT)
For questions and discussions related to Intel® QuickAssist Technology (Intel® QAT).
96 Discussions
how to register with linux kernel crypto framework for QAT in-tree driver
Zhang_Li
Hi all,
We tried both in-tree and out-of-tree drivers of QAT, and we want to use it via LKCF, for the OOT driver we can see that:
# cat /proc/crypto | grep qat
driver       : qat_aes_cbc_hmac_sha512
module       : intel_qat
driver       : qat_aes_cbc_hmac_sha256
module       : intel_qat
driver       : qat_aes_cbc_hmac_sha1
module       : intel_qat
driver       : qat_aes_xts
module       : intel_qat
driver       : qat_aes_ctr
module       : intel_qat
module       : intel_qat
but it was empty when we tried the in-tree driver in kernel-5.19 while all of the others seem normal(qat service running mormally)
Can you tell us how should we do if we want to use in-tree driver of QAT via LKCF? Thanks in advance.
Victor_G_Intel
Hello Li_Z_Intel,
Please let me review this information internally, and kindly wait for an update.
Once we have more information to share, we will post it on this thread.
Victor G.
Intel Technical Support Technician
Victor_G_Intel
Hello Li_Z_Intel,
Thank you for your patience.
In regard to your request, in-tree driver should already be registered with LKCF. The following command can be used to check the available drivers: cat /proc/crypto | grep -B 4 passed | grep qat[-_]
Note that if qatlib is installed, all QAT endpoints will be assigned to user space, so none would be available for kernel. If that's the case, simply uninstall qatlib and reboot.
Victor G.
Victor_G_Intel
Hello Li_Z_Intel,
Please let me know if you need further assistance.
Victor G.
Zhang_Li
Hi Victor,
Many thanks for your great support! Sorry for not being sure why I can't reply normally here these days.
[A] actually we did not install qatlib. Now the system was reinstalled, so we will continue to try it.
Victor_G_Intel
Hello Li_Z_Intel,
We appreciate your response.
Please keep us posted in case you need further assistance after installing qatlib.
Victor G.
Zhang_Li
Hi Victor,
I updated the kernel using https://github.com/intel-innersource/drivers.qat.linux.qatkernel .
After reboot, I can see qat in /proc/crypto, but the qat service status is not right, and from /sys/kernel
# ls /sys/kernel/debug/qat_4xxx_0000\:6b\:00.0/
dev_cfg transport
There are no "fw_counters" and others in this folder.
After installing qatlib, it is the same as before.
Victor_G_Intel
Hello Li_Z_Intel,
Thank you for your response
The link you provided is pointing to a private GitHub repo used for internal development, not for production. We don't recommend using it unless you are internally developing with QAT. In such cases, it's better to refer to the development team in GitHub about any issues when using that repo as it goes beyond the scope of our support.
Also, the qatlib we are referring to is the one found here: https://github.com/intel/qatlib. The qatlib is compatible only with 4xxx (QAT gen 4 devices)
Additionally, to use the QAT in-tree driver, qatlib is not really needed. In fact, if qatlib is installed, all QAT endpoints will be assigned to user space, so none would be available for kernel.
Victor G.
Victor_G_Intel
Hello Li_Z_Intel,
Victor G.
Zhang_Li
Hi Victor,
Many thanks for your great help and sorry that I did not see the previous reply.
For this issue, we can close it. According to your previous answer, we have understood the problem, thank you very much.
Victor_G_Intel
Hello Li_Z_Intel,
Thank you for yoru response.
We are glad to know that the information provided has been helpful. Since the thread is now solved, we will proceed to close it.
Victor G.
