Intel® Rendering Toolkit
Receive answers to your big data visualization questions from community peers and Intel experts.
This forum offers only peer-to-peer support. Thank you!
39 Discussions
OneVPL sample_decode is giving DeliverOutput return error = -1 with -r rendering option
Sushant35
Hi
    I am just exploring OneVPL samples and facing a issue on below system specifications GPU Gen -Intel  ADL
Linux  6.2.0-33-generic #33~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Thu Sep 7 10:33:52 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
i am running this command
sample_decode h265 -device /dev/dri/renderD128 -i /home/Collab8/oneVPL/examples/content/cars_320x240.h265 -r
and in output it is not able to render with below output :-
CONFIGURE LOADER: required implementation: hw
CONFIGURE LOADER: required implementation mfxAccelerationMode: MFX_ACCEL_MODE_VIA_VAAPI
libva info: VA-API version 1.21.0
libva info: Trying to open /usr/lib64/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_21
libva info: va_openDriver() returns 0
pretending that aspect ratio is 1:1
Loaded Library configuration:
Version: 2.9
ImplName: mfx-gen
Adapter number : 0
Adapter type: integrated
DRMRenderNodeNum: 128
Used implementation number: 0
Loaded modules:
0: /usr/lib/x86_64-linux-gnu/libmfxhw64.so.1.35_bkp
1: /usr/lib/x86_64-linux-gnu/libmfx-gen.so.1.2.9
Decoding Sample Version 8.4.27.0
Input video HEVC
Output format NV12
Input:
Resolution 320x240
Crop X,Y,W,H 0,0,320,240
Output:
Resolution 320x240
Frame rate 25.00
Memory type vaapi
MediaSDK impl hw
MediaSDK version 2.9
Decoding started
DeliverOutput return error = -1 fread_fps: 0.000, fwrite_fps: 0.000
Frame number: 1, fps: 22.019, fread_fps: 0.000, fwrite_fps: 0.000
Decoding finished
and rendering fails
please find my vainfo details below:
Trying display: wayland
error: XDG_RUNTIME_DIR not set in the environment.
Trying display: drm
vainfo: VA-API version: 1.21 (libva 2.21.0.1)
vainfo: Driver version: Intel iHD driver for Intel(R) Gen Graphics - 23.3.4 (b60f5d693)
vainfo: Supported profile and entrypoints
VAProfileNone : VAEntrypointVideoProc
VAProfileNone : VAEntrypointStats
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Simple : VAEntrypointEncSlice
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointFEI
VAProfileH264Main : VAEntrypointEncSliceLP
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileH264High : VAEntrypointFEI
VAProfileH264High : VAEntrypointEncSliceLP
VAProfileVC1Simple : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointEncPicture
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264ConstrainedBaseline: VAEntrypointFEI
VAProfileH264ConstrainedBaseline: VAEntrypointEncSliceLP
VAProfileHEVCMain : VAEntrypointVLD
VAProfileHEVCMain : VAEntrypointEncSlice
VAProfileHEVCMain : VAEntrypointFEI
VAProfileHEVCMain : VAEntrypointEncSliceLP
VAProfileHEVCMain10 : VAEntrypointVLD
VAProfileHEVCMain10 : VAEntrypointEncSlice
VAProfileHEVCMain10 : VAEntrypointEncSliceLP
VAProfileVP9Profile0 : VAEntrypointVLD
VAProfileVP9Profile0 : VAEntrypointEncSliceLP
VAProfileVP9Profile1 : VAEntrypointVLD
VAProfileVP9Profile1 : VAEntrypointEncSliceLP
VAProfileVP9Profile2 : VAEntrypointVLD
VAProfileVP9Profile2 : VAEntrypointEncSliceLP
VAProfileVP9Profile3 : VAEntrypointVLD
VAProfileVP9Profile3 : VAEntrypointEncSliceLP
VAProfileHEVCMain12 : VAEntrypointVLD
VAProfileHEVCMain12 : VAEntrypointEncSlice
VAProfileHEVCMain422_10 : VAEntrypointVLD
VAProfileHEVCMain422_10 : VAEntrypointEncSlice
VAProfileHEVCMain422_12 : VAEntrypointVLD
VAProfileHEVCMain422_12 : VAEntrypointEncSlice
VAProfileHEVCMain444 : VAEntrypointVLD
VAProfileHEVCMain444 : VAEntrypointEncSliceLP
VAProfileHEVCMain444_10 : VAEntrypointVLD
VAProfileHEVCMain444_10 : VAEntrypointEncSliceLP
VAProfileHEVCMain444_12 : VAEntrypointVLD
VAProfileHEVCSccMain : VAEntrypointVLD
VAProfileHEVCSccMain : VAEntrypointEncSliceLP
VAProfileHEVCSccMain10 : VAEntrypointVLD
VAProfileHEVCSccMain10 : VAEntrypointEncSliceLP
VAProfileHEVCSccMain444 : VAEntrypointVLD
VAProfileHEVCSccMain444 : VAEntrypointEncSliceLP
VAProfileAV1Profile0 : VAEntrypointVLD
VAProfileHEVCSccMain444_10 : VAEntrypointVLD
VAProfileHEVCSccMain444_10 : VAEntrypointEncSliceLP
Hugo_Intel
Hello Sushant35
Thank you for posting on the Intel️® communities.
 We will move your question to the correct sub-forum, the team in charge will get back to you soon.
Best regards,
Hugo O.
Intel Customer Support Technician
