Intel® Rendering Toolkit
Receive answers to your big data visualization questions from community peers and Intel experts.
This forum offers only peer-to-peer support. Thank you!
36 Discussions
aidevcloud: Permission denied (publickey). stcuk in step 1.4 with this error
iga
after /opt/TurboVNC/bin/vncserver -otp
I've opened new cygwin terminal and entered ssh sXXX-nXXX.aidevcloud with my name insted X
and just this happend.
Also tryed to do this command in current window and then I can't do turbonvc localhost:1 connection
JyothisV_Intel
Good day to you.
There was an issue with Intel DevCloud recently that prevented you from accessing the renderkit nodes using TurboVNC. Our Intel DevCloud admin team has informed that the issue is now resolved. Can you try following the guide below again and confirm if the issue is resolved or not?
https://devcloud.intel.com/oneapi/documentation/rendering-toolkit-for-linux/
If you are still getting any public key errors, kindly re-configure the connection to Intel DevCloud by following the "Automated Configuration (Recommended)" guide provided in the link below:
https://devcloud.intel.com/oneapi/documentation/connect-with-ssh-windows-cygwin/#configure-ssh-connection
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue.
Thanks and Regards,
Jyothis V James
JyothisV_Intel
Good day to you.
We are checking on this internally and will get back to you with an update soon.
Jyothis V James
JyothisV_Intel
Good day to you.
Thanks and Regards,
Jyothis V James
JyothisV_Intel
Good day to you.
Thanks for accepting our solution. Glad to know that your issue is resolved.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jyothis V James
