Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
About EPC size
sera_l_
At SGXv1, there is a EPC limitation 128MB.
is there a plan for extending the maximum size of EPC at SGXv2?
I know that SGXv2 will be releasing with Dynamic memory allocation feature. Does it mean that the maximum size of EPC is fixed and when the memory is allocated more than the maximum size, the page will be swapped?
thanks
Anusha_K_Intel
In SGX2  there is  Statically Allocated  memory and dynamically allocated memory. The size of the statically allocated memory is fixed and  the value is not known as of now. SGX2 Extensions give software the ability to dynamically add and remove pages from an enclave and to manage the attributes of enclave pages.comparision.png
In Section 4 of this document you can read how the dynamic memory management is done--http://caslab.csl.yale.edu/workshops/hasp2016/HASP16-17.pdf
http://caslab.csl.yale.edu/workshops/hasp2016/HASP16-16_slides.pdf
http://www.cs.wayne.edu/fengwei/16fa-csc6991/slides/5-SGX1.pdf
Anusha
