Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1545 Discussions
Breakpoints in Enclave codes does not work at x64 platform in Windows 10 version 1607
Jaehyeong_H_
Hi
Windows 10 version 1607 was released a month ago
While I was using Windows 10 Version 1511, breakpoints in Enclaves codes works well.
After I updated Windows 10 version 1607, breakpoints in Enclave codes does not work at x64 platform.
How can I fix this problem?
Jaehyeong Ha
Surenthar_S_Intel
Debugger breakpoints inside enclaves do not work in Windows 10 Anniversary Edition (version 1607). We are working on a resolution for this issue and will let you know when there is an ETA. All other SGX behavior functions normally / as expected. If you need to debug inside an enclave please use Windows 10 Fall Update (version 1511) or an earlier version of Windows.
-Surenthar
Surenthar_S_Intel
Cumulative Update for Windows 10 Version 1607 and Windows Server 2016: December 9, 2016 - https://support.microsoft.com/en-us/kb/3201845
This updated my OS version to 10.0.14393.479
Now I can set breakpoints inside enclaves and WriteProcessMemory() works on RX enclave memory.
-Surenthar
AArya2
I'm having the same problem with 1607 x64.
Is there a particular project setting in Visual Studio that I might be missing?
Arya
AArya2
No problem with the release. I just hadn't set the untrusted app's debugger to "Intel SGX Debugger".
Arya
