Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1550 Discussions
Build/run issue of inte-sgx-ssl in SIM mode on AMD Ryzen 5 + CentOS8.2
das__batsayan
I am using Centos 8.2 on AMD Ryzen 5 4500U. I installed SGX SDK 2.12 and want to install ssl( from https://github.com/intel/intel-sgx-ssl) using the following command "make SGX_MODE=SIM all test"
I get the following error
make[2]: Entering directory '/home/batsayan/work/intel-sgx-ssl/Linux/sgx/test_app'
make -f sgx_u.mk test
make[3]: Entering directory '/home/batsayan/work/intel-sgx-ssl/Linux/sgx/test_app'
token_path: /home/batsayan/enclave.token
make[3]: *** [sgx_u.mk:108: test] Illegal instruction (core dumped)
make[3]: Leaving directory '/home/batsayan/work/intel-sgx-ssl/Linux/sgx/test_app'
Won't the sgx application build in SIM mode run on AMD Ryzen based laptop? I built and ran Samples inside SDK in SIM mode without any issue. Faced the above error when try to build sgxssl.
I can compile ~intel-sgx-ssl/Linux/sgx/test_app using "make SGX_MODE=SIM" , but when I run the TestApp it is showing
$./TestApp
TIA for any help.
--Batsayan
JesusG_Intel
Hello batsyan,
Intel-sgx-ssl is not supported on AMD Ryzen 5 since Intel does not validate it. I'm sorry I couldn't be more helpful.
Sincerely,
Jesus G.
Intel Customer Support
JesusG_Intel
Hello batsyan,
Sincerely,
Jesus G.
JesusG_Intel
This thread has been marked as answered and Intel will no longer monitor this thread. If you want a response from Intel in a follow-up question, please open a new thread.
