Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Can I create another enclave in an enclave?
MYEONGSU__KIM
function_in_enclave(eid1)   <---- e-called
   sgx_create_enclave(eid1, ~~~~);
Is this possible??
Scott_R_Intel
Hello.
No, this is not supported.  If you need two enclaves, you create them both from the untrusted app and then can use local attestation to communicate between the two if need be.
Regards.
Scott
