Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Can't install sgx add-in to VS2019
pheles
Hello, Im quite new to Intel SGX development.  Currently I'm trying to build the environment to debug and compile my code however I'm not able to eventhough I installed SGX SDK. As I understood there should be an enclave project option while creating a new project but I don't seem to have it. Do I have add the files manually? Would anybody care to help? Thanks in advance!
JesusG_Intel
Hello pheles,
Refer to Unable to Manually Install the Visual Studio* 2019 add-in from the Intel® Software Guard Extensions (Intel® SGX) Software Development Kit (SDK) for Windows*
  1. Rename Intel(R)_SGX_Windows_SDK_2.12.100.4.exe to Intel(R)_SGX_Windows_SDK_2.12.100.4.zip.
  2. Double-click the .zip file and navigate to the installs subdirectory where you will find the .vsix files.
  3. Extract the .vsix files.
  4. Double-click SEWizardVS2019.vsixClick Next if necessary.
  5. Double-click SEConfigureVS2019.vsixClick Next if necessary.
  6. Change the extension of the .zip file back to .exe and install the SDK as usual.
Sincerely,
Jesus G.
Intel Customer Support
JesusG_Intel
Hello pheles,
Sincerely,
Jesus G.
pheles
Hello again! Thank you so much for the help it did the trick!
JesusG_Intel
This thread has been marked as answered and Intel will no longer monitor this thread. If you want a response from Intel in a follow-up question, please open a new thread.
