Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
Configuring Sawtooth to Use SGX
George_M_1
I follow the steps from here: https://sawtooth.hyperledger.org/docs/core/releases/latest/sysadmin_guide/configure_sgx.html and in this step:
Create and submit a proposal:
$ sawtooth config proposal create -k /etc/sawtooth/keys/validator.priv \ sawtooth.consensus.algorithm=poet \ sawtooth.poet.report_public_key_pem="$(cat /etc/sawtooth/ias_rk_pub.pem)" \ sawtooth.poet.valid_enclave_measurements=$(poet enclave --enclave-module sgx measurement) \ sawtooth.poet.valid_enclave_basenames=$(poet enclave --enclave-module sgx basename) \ sawtooth.poet.enclave_module_name=poet_enclave_sgx.poet_enclave \ -o config.batch
I get the following:
sawtooth@dsg2:/tmp$ sawtooth config proposal create -k /etc/sawtooth/keys/validator.priv \
> -o config.batch
[17:50:12 WARNING poet_enclave] SGX PoET enclave initialized.
Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 560, in urlopen
body=body, headers=headers)
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 346, in _make_request
self._validate_conn(conn)
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 787, in _validate_conn
conn.connect()
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 252, in connect
ssl_version=resolved_ssl_version)
File "/usr/lib/python3/dist-packages/urllib3/util/ssl_.py", line 303, in ssl_wrap_socket
context.load_cert_chain(certfile, keyfile)
ssl.SSLError: [SSL] PEM lib (_ssl.c:2825)
During handling of the above exception, another exception occurred:
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 376, in send
timeout=timeout
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 589, in urlopen
raise SSLError(e)
requests.packages.urllib3.exceptions.SSLError: [SSL] PEM lib (_ssl.c:2825)
File "/usr/lib/python3/dist-packages/sawtooth_poet_cli/main.py", line 131, in main_wrapper
main()
File "/usr/lib/python3/dist-packages/sawtooth_poet_cli/main.py", line 123, in main
do_enclave(args)
File "/usr/lib/python3/dist-packages/sawtooth_poet_cli/enclave.py", line 52, in do_enclave
data_dir=config.get_data_dir()) as poet_enclave_module:
File "/usr/lib/python3/dist-packages/sawtooth_poet_cli/poet_enclave_module_wrapper.py", line 58, in __init__
self._poet_enclave_module.initialize(config_dir, data_dir)
File "/usr/lib/python3/dist-packages/sawtooth_poet_sgx/poet_enclave_sgx/poet_enclave.py", line 532, in initialize
update_sig_rl()
File "/usr/lib/python3/dist-packages/sawtooth_poet_sgx/poet_enclave_sgx/poet_enclave.py", line 462, in update_sig_rl
sig_rl = _ias.get_signature_revocation_lists(_epid_group)
File "/usr/lib/python3/dist-packages/sawtooth_ias_client/ias_client.py", line 51, in get_signature_revocation_lists
result = requests.get(url, cert=self._cert, timeout=self._timeout)
File "/usr/lib/python3/dist-packages/requests/api.py", line 67, in get
return request('get', url, params=params, **kwargs)
File "/usr/lib/python3/dist-packages/requests/api.py", line 53, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 468, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 576, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 447, in send
raise SSLError(e, request=request)
requests.exceptions.SSLError: [SSL] PEM lib (_ssl.c:2825)
[17:50:13 WARNING poet_enclave] SGX PoET enclave initialized.
conn.connect()
timeout=timeout
raise SSLError(e)
main()
do_enclave(args)
update_sig_rl()
sawtooth@dsg2:/tmp$
My certificate was made by this tutorial: https://software.intel.com/en-us/articles/how-to-create-self-signed-certificates-for-use-with-intel-sgx-remote-attestation-using
and i got for result these files: client.cnf, client.crt, client.key, client.pfx, client.req
So i renamed client.key to sgx-certificate.pem and then i used it as shown in the tutorial for configuring sawtooth with sgx
I have ubuntu 16.04 with all the updates in a physical enviroment.
Nishida__Yoshi
You will need to do something like the following to generate a PEM file. $ cat cert.crt cert.key > cert.pem or $ openssl pkcs12 -in cert.pfx -out cert.pem -nodes Hope this works.
