Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Creating & adding data to an enclave
horesh__gal
Hello, I'm having troubles creating/adding data to an enclave.
From the tutorials I've seen, the instructions used to manage the enclave are the E-instructions (ECREATE, EADD, etc..) but I haven't seen a guide that clearly explains how to use them.
My current goal is to put data into the enclave in such way that if an unauthorized process tries to access the memory of the enclave I've generated (EPC page) , then the "abort page semantics" will take actions - any attemp to read the data will result with a value of -1.
Should I use these E-instructions in order to reassure my data is securily stored in the enclave I have created? If so, which libraries do I need?
Gal.
Scott_R_Intel
Hello Gal.
In order to use SGX, yes, the "E-instructions" will need to be utilized.  But, unless you really want to, you don't have to write it all from scratch.  The SGX SDK (Software Development Kit) in combination with the SGX PSW (Platform Software) makes it easier to write enclaves and untrusted enclave calling applications.  Please have a look at our open source SGX projects for more information.
https://01.org/intel-software-guard-extensions/
https://github.com/intel/linux-sgx
https://github.com/intel/linux-sgx-driver
Regards.
Scott
horesh__gal
Thank you Scott, I'll check it out.
 Gal.
