Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1545 Discussions
Do we need to Register Azure VM Platform for SGX Remote Attesation ?
Sirasapalli
Hi, I have setup Azure Attestation Provider, and trying to run an application, with configuration below
"pccs_url": "https://<<attestation url>>/certs",
"use_secure_cert": true,
"collateral_service": "https://<<attestation url>>/certs"
"local_pck_url": "https://<<attestation url>>/certs"
It always throws No Evidence provided on handshake data, and some time pckcert Wrong tag.
Can someone help what could the process to make the application run without errors?
Labels (3)
Scott_R_Intel
Hello.
If you're trying to download PCK Certs for Azure platforms directly from Intel, you cannot.  You need to get the platform PCK Certs for Azure platforms from their THIMS service.  Please refer to the config file linked below for the correct URLs:
https://github.com/intel/SGXDataCenterAttestationPrimitives/blob/main/QuoteGeneration/qcnl/linux/sgx_default_qcnl_azure.conf
Regards.
