Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
Enclave attestation returns empty evidence
Roman888
I'm trying to setup this service
https://github.com/signalapp/ContactDiscoveryService-Icelake
It uses SGX+OpenEnclave
Renting Azure Confidential Compute, Ubuntu 20.04
Service started and perform initial self-attestation successfully without errors.
But when it receives request from IOS mobile client which initiate another one attestation I getting next error: "SGX operation failed: attestation data invalid: Evidence does not fit expected format".
After debugging I find out that mobile client perform enclave attestation and receives some "ereport" object with empty "evidence" field, and mobile client aborting connection with enclave with that error above. And there are no any errors from backend side, as I understood just some bad response from enclave and it failed validation on client side.
VM Installed libs:
libsgx-ae-id-enclave/unknown,now 1.22.100.3-focal1 amd64 [installed,automatic]
libsgx-ae-pce/unknown,now 2.25.100.3-focal1 amd64 [installed,automatic]
libsgx-ae-qe3/unknown,now 1.22.100.3-focal1 amd64 [installed,automatic]
libsgx-ae-qve/unknown,now 1.22.100.3-focal1 amd64 [installed,automatic]
libsgx-aesm-ecdsa-plugin/unknown,now 2.25.100.3-focal1 amd64 [installed]
libsgx-aesm-pce-plugin/unknown,now 2.25.100.3-focal1 amd64 [installed,automatic]
libsgx-aesm-quote-ex-plugin/unknown,now 2.25.100.3-focal1 amd64 [installed]
libsgx-dcap-default-qpl-dev/unknown,now 1.22.100.3-focal1 amd64 [installed]
libsgx-dcap-default-qpl/unknown,now 1.22.100.3-focal1 amd64 [installed]
libsgx-dcap-ql-dev/unknown,now 1.22.100.3-focal1 amd64 [installed]
libsgx-dcap-ql/unknown,now 1.22.100.3-focal1 amd64 [installed]
libsgx-dcap-quote-verify/unknown,now 1.22.100.3-focal1 amd64 [installed,automatic]
libsgx-enclave-common/unknown,now 2.25.100.3-focal1 amd64 [installed,automatic]
libsgx-headers/unknown,now 2.25.100.3-focal1 amd64 [installed,automatic]
libsgx-pce-logic/unknown,now 1.22.100.3-focal1 amd64 [installed,automatic]
libsgx-qe3-logic/unknown,now 1.22.100.3-focal1 amd64 [installed,automatic]
libsgx-quote-ex/unknown,now 2.25.100.3-focal1 amd64 [installed]
libsgx-urts/unknown,now 2.25.100.3-focal1 amd64 [installed,automatic]
linux-base-sgx/focal-updates,now 4.5ubuntu3.7 all [installed]
sgx-aesm-service/unknown,now 2.25.100.3-focal1 amd64 [installed]
I didn't install az-dcap-client instead of libsgx-dcap-default-qpl since with it application will fail on startup during initial self attestation with some error about bad ASN field format...
Also as I understand this lib will be discounted in future, and instead of it it's enough to use libsgx-dcap-default-qpl with correct sgx_default_qcnl.conf, here is mine:
    "pccs_url": "https://global.acccache.azure.net/sgx/certification/v4/",
    "use_secure_cert": false,
    "collateral_service": "https://api.trustedservices.intel.com/sgx/certification/v4/",
    "pccs_api_version": "3.1",
    "retry_times": 6,
    "retry_delay": 5,
    "local_pck_url": "http://169.254.169.254/metadata/THIM/sgx/certification/v4/",
    "pck_cache_expire_hours": 48,
    "verify_collateral_cache_expire_hours": 48,
    "custom_request_options": {
        "get_cert": {
            "headers": {
                "metadata": "true"
            "params": {
                "api-version": "2021-07-22-preview"
With this config remote attestation sample are working from OE, and Intel.
Here is also my aesmd log which seems to be also ok:
And there is my certificate from this log, looks like also good:
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
So, please help, is my setup correct, or what's the problem with it?
