Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Error STATUS_SGX_CRL_UNKNOWN_ISSUER
Elod
I am using AttestationApp from repository: https://github.com/intel/SGX-TDX-DCAP-QuoteVerificationLibrary/tree/v1.1.8180 and got this error:
$ LD_LIBRARY_PATH=./ ./AttestationApp --rootCaCrl=IntelSGXRootCA.der
Running QVL version: 1.0.0
Verification results: false
AppLogs:
PCK certificate chain verification failed with status: STATUS_SGX_CRL_UNKNOWN_ISSUER(29)
TCB info verification OK!
Quote verification failed with status: STATUS_INVALID_PCK_CRL(41)
Collateral data is collected from PCCS via its API, PCCS was provisioned with PCKIDRetrievalTool.
Note: I already found similar issue reported here and I have tested suggestions without no success.
Do you know what is causing the `STATUS_SGX_CRL_UNKNOWN_ISSUER` error and how I can fix it?
Thank you,
Elod
Labels (5)
Elod
Solved my issue.
I was collecting pckCrl.der file from the wrong source.
Using the correct source, url from the pckCert\X509v3 CRL Distribution Points solved my issue.
Elod
Solved my issue.
