Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
1558 Discussions
Error when building "dynamic-application-loader-host-interface” project
marcos_a_
Hi all,
I am following the instructions from https://github.com/01org/linux-sgx to build my dynamic-application-loader-host-interface project.
This is part of "Install Intel(R) SGX PSW" section on the same document.
So, I downloaded the source code for "dynamic-application-loader-host-interface”.
Then, when I run "sudo cmake ." from the folder where the source code is located, I am getting the following error:
"Cannot find source file:
   common/reg-Linux.cpp"
I looked at /common directory and reg-Linux.cpp file is not there.
Does anybody knows why it is missing or how to fix this problem?
Rgds
Marcos
marcos_a_
Ok, I realized that the zip file I got from github was missing that cpp.
I downloaded again and the built worked fine.
marcos
