Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
For unsupported C++ functions
sera_l_
I want to change my cpp codes to SGX code. But there are some issues related with unsupported C++ functions(or classes) like iostream, sstream.
Should I make ocalls for them to use this features?
And there is one more question.
I found some interfaces about unsupported class at SGX SDK (e.g sgxsdk/include/stlport/stl/_sstream.h)
Does It mean that is it working when I replace "<sstream>" to "<stl/_sstream.h>" in my default c++ codes? I tried to do this but I faced the problem that the header file in sdk is pointing at the untrusted code. In more details, the header file "_threads.h" in sdk is pointing at "/usr/include/pthread.h". so the redefinition type error happended.
Please help me :)
Surenthar_S_Intel
Question No 1: Yes.
Question No 2: Could you please tell me which version of Visual Studio are you using to develop SGX application? Use the latest SDK and Visual Studiuo 2015.
-Surenthar Selvaraj
Juan_d_Intel
Don't include files from stlport/stl directly.
We removed unsupported header files from the stlport directory, but only modified supported header files in stlport/stl.
For example, if sstream is not included in stlport, then you should not include stl/_sstream.h
