Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1545 Discussions
Generation of root certificate and PCK Certificate in DCAP remote authentication
enclave_Research
How is the root secret key and PCK secret key generated in DCAP remote authentication,and How are root certificates and PCK certificates generated in DCAP remote authentication?
JesusG_Intel
Hello enclave_research,
The Introduction and Terminology sections of this paper, Remote Attestation for Multipackage Platforms using Intel SGX DCAP, will shed more light on your questions. This is all the information we have at this moment.
Sincerely,
Jesus G.
Intel Customer Support
JesusG_Intel
Hello enclave_Research,
The DCAP Orientation Guide  and the Intel SGX PCK Certificate CRL Spec contain all of the information you need.
The basic steps to receive the PCK certs from the Intel Attestation Service are:
  1. Subscribe at the ECDSA Attestation Service to be able to receive and cache the PCK certs.
  2. Setup Intel SGX DCAP environment.
  3. Build and install the Provisioning Certificate Caching Service (PCCS)
  4. Generate pckid_retrieval.csv
  5. Run PCKIDRetrievalTool to download and cache the certs into your PCCS.
The QuoteGeneration Sample shows how to get the cert data from the quote.
Sincerely,
Jesus G.
enclave_Research
@JesusG_Intel
Hello!I know how to retrieve the PCK certificate. I want to know where, when and how the Intel root certificate and PCK certificate are generated? Thanks for your answer.
JesusG_Intel
This DCAP paper has more technical details on the certs. I am checking with my resources if we can provide more specific information, but that information may not be publicly disclosable.
Sincerely,
Jesus G.
JesusG_Intel
Sincerely,
Jesus G.
JesusG_Intel
Do you still need help with this issue?
Sincerely,
Jesus G.
