Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Get enclave ID of caller from inside an OCALL
lieser__philippe
from inside an OCALL, I would like to get the enclave ID (sgx_enclave_id_t) of the enclave calling this OCALL function.
Does someone know if and how this is possible?
Francisco_C_Intel
No.
I believe you'll need to save it to a global variable (if there's only one instance of an enclave) or pass it as a parameter from the app to the enclave so that the enclave can then pass it to the ocall.
Francisco
