Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Google Native Client (NaCl) modules using SGX Enclaves
Rafael_C_
Hi, I'm trying to make an PNaCl module that uses functions that run inside SGX Enclaves (ECALLs) but without any success so far. I'm not sure if this is possible considering NaCl's compiler specificities and the fact that both technologies works with memory access constrains. To make this possible I think enclave memory should be entirely inside the NaCl module limits.
I'm using the linux sgx sdk. A regular SGX application uses the executable file and a signed.enclave.so library. Is it possible to compile the signed.enclave.so using NaCl compiler and then unite it with the main application in a single nexe/pexe file?
Also, is it possible to take advantage of the sgx sdk libraries using the pnacl-ar and pnacl-ranlib tools?
Does anyone has ever tried something like this? Any sucesses? Ideas on how to do it?
Thanks a lot.
Surenthar_S_Intel
Enclaves must be 100% native code, with no dependancies on shared libraries. There are no exceptions to these restrictions. The linkages to the ECALLs in your enclave, and the OCALLs made from your enclave, must be 100% native C (not C++) code. There are no exceptions to this restriction and perhaps most important, enclaves have to be built using the trusted C and C++ libraries provided by Intel. They are built to provide C/C++ libraries that do not contain instructions and operations that are not legal inside of enclaves. There's really not a practical way to "build" an enclave outside of the process.
-Surenthar
