Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1541 Discussions
How can I use sgx in a computer whose hardware don't support sgx?
jianlin__jiang
How to use simulation of sgx in my project in Visual Studio 2015?(the version of sgx is 1.9.)
My computer's CPU don't support sgx。
you_w_
New Contributor III
Hi:
You can install the sgx sdk, there are some examples in your install path like "C:\Program Files (x86)\Intel\IntelSGXSDK\src".
1. Open SampleEnclave.sln.
2. Change your build mode to “Simulation”
3. Select your project  and change the project platform tool chain to:Visual Studio 2015 && change you windows sdk version
to the one you installed like “10.0.16299.0”
Then your can build the project in simulation mode.
