Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
How to pass a parameter which the type is a class
dai_c_
Hello guys:
     I am a freshman of SGX, I want protect a function which its parameter is a class,and how can I pass it to enclave?
 for example:
and edl file not support "class"
you_w_
New Contributor III
Hi dai c.:
Actually the interface for sgx can only be write with C programming language. You can use struct instead.
you
Hoang_N_Intel
I assume that if you really want to use C++, you can use C++ object serialization technique to get in and out the Enclave instead of using struct. But it does add some overhead.
dai_c_
Yes,It's a good idea! I have a try in C++ object serialization technique,but many header files used by serialization is  unsupported in SGX, SDK e.g./boost/archive/text_oarchive.hpp ,boost/archive/text_iarchive.hpp.  and also some frequently used header files in C++ is unsupported in SGX SDK,like iostream,sstream and so on.
dai_c_
you w. wrote:
Hi dai c.:
you
Actually, I use SGX SDK to protect some modules of a massive C++ project, and it's hard to change class into struct. and the mainly problem is I can't  pass C++ object by edl file
